Removing Harmonic Balancer/Crankshaft pully
Old Nov 1, 2006 | 11:33 AM
GVOLCRunner's Avatar
Ok,
So some how the pully on my balancer has seperated. It needs to be replaced. Im nervous when dealing with any timing issue.
So, I have a harmonic puller; but Im wondering what I should do to remove the big bolt in the center? And, does this have to be done without turning the crankshaft pulley? if so, how do I go about doing that? I have a torqe wrench but never removed this before and wanted to ask before I possibly mess something up.
Thank you in advance
Old Nov 1, 2006 | 11:44 AM
bballchrism's Avatar
we removed our bolt by geting a big breaker bar and putting it up agiasnt the fame a bumping the starter
Old Nov 1, 2006 | 12:12 PM
984RNR's Avatar
Ditto on the Starter trick
Better have an impact wrench to retorque it because i think its something like 220 ft lbs
Old Nov 1, 2006 | 12:27 PM
snap-on's Avatar
you wont mess up the timming as the timming belt (this is a V6 right?) is driven off a bottom belt gear that is keyed to the crank shaft. so even if you pull the pully off, the timming belt is good.
Just make shure you get the pulley back on or else.... (ive got a thread around hear of what happens when you dont)
Old Mar 20, 2008 | 12:44 PM
azredliner's Avatar
It's 120 and DON'T USE AN IMPACT!
I chained a flywheel bolt from the crankshaft to the engine stand and it came right off using a 24" breaker.
Old Mar 20, 2008 | 01:18 PM
toy_tek's Avatar
x2. Impact wrench is NOT a torque wrench. Use the right tool for the job.
Old Mar 20, 2008 | 01:24 PM
1lowtoy's Avatar
Definitely dont use a impact wrench. You dont wana strip your bolts or worse, the threads on your crank shaft.
Old Mar 20, 2008 | 01:55 PM
blarchitect's Avatar
If you dont have a breaker bar, use a length of 3/4" dia copper or steel pipe over the end of your wrench.
Old Mar 20, 2008 | 02:10 PM
hross14's Avatar
HUH??I know it is 213. This is a V-6 right.
Impact it to get it off--its-a-nice
THen i think i saw somebody on here make a pully holder out of a 2x4--but you only get so many uses.....then its worn out--but cheap!!
If this is a V-6 the pully/balancer bolt should be torqued to 213 ft lbs
Old Mar 20, 2008 | 03:32 PM
mt_goat's Avatar
Pretty close , the 5VZFE crank bolt spec is 217 ft-lbs now, old spec was 185 ft-lb. The old spec is not enough torque to prevent the bolt from working loose. Several folks on here have had major problems from their crank bolt loosening up and doing damage to their crank. Again this is for the 5VZFE, I don't know about the 4 cyl engines, the OP didn't say what engine he has.
Links to FSM pages covering crank bolt torque:
5VZFE http://www.ncttora.com/fsm/2003/Repa...imbel/inst.pdf
2RZ–FE, 3RZ–FE http://www.ncttora.com/fsm/2003/Repa...imcha/inst.pdf
Looks like the 4 cyl engines take 193 ft-lbs.
Old Mar 20, 2008 | 04:28 PM
azredliner's Avatar
I googled a 4 cylinder and assumed this thread was talking about a 22R. I saw that bit about using an impact on the harmonic balancer and got excited!
I know... Don't ASS-U-ME!
choppe777
May 16, 2016 08:00 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
old87yota
Sep 9, 2015 12:39 PM
gp66
Sep 7, 2015 08:29 AM
Aaron Logan
Sep 3, 2015 08:08 AM
