Steering wheel wobbles and shakes.
This is on an 86' 4runner with 33" tires, 204k miles. Pretty recently my steering wheel will wobble and shake, usually on deceleration. I just got done jacking up both sides of the truck and wiggled the tires forward and back with my hands at the 12 o'clock and 6 o'clock positions and have more play than I prefer. I think it may have to do with worn hub bushings? Both sides wobbled but the tires spun freely with no noises and no rough spots so I don't think it's the wheel bearings. Any ideas?
The deceleration vibration problem was caused by loose driveshaft bolts. However, I still have a wobble in the steering wheel on the highway and goes away when I apply the brakes or slow down. Maybe ball joints?
Ball joints are another possibility. You can not detect play in your ball joints by simply shaking the tire with your hand. You'll need to jack it up, stick a metal bar under the tire and pry it up while someone watches the BJ from the front for movement.
The owner before me has a flat spot on one of the back tires that used to be on the front from a wheel bearing freezing up on him. I'll get everything I need tomorrow and check the ball joints while I'm replacing the bearings. Thanks!
terminator
Jul 27, 2015 07:13 PM
Old Man Emu Steering Stabilizer and no more play!!!
