36x13.50 iroks on a 15x7 wheel
Old Oct 24, 2006 | 05:00 PM
titicaca's Avatar
willl they fit? im thinking it may actually be better and would allow me to air down alot more without the bead breaking as easily. would it make a difference if i went radial or bias ply as far as the wheel issue?
Old Oct 24, 2006 | 05:09 PM
CJM's Avatar
CJM
They may fit but it will be a tight squeeze, I think you would be better off with 35x12.5 or using bigger rims ike 15x8 or 15x10.
Old Oct 24, 2006 | 05:55 PM
titicaca's Avatar
i have 33x12.50's on them now but i figure that the extra 1/2 an inch on each side wont be a big differance. the wheels may be 15x8 , the 33's fit nicely, maybe i should try to measure for sure. the tires only stick out a little bit more than the wheels. the righ is mostly an offroad rig with maybe 25 % on the road at most.
i was just trying to save a few hundred on wheels, i may end up with a set of 15x10 street loks.
Old Oct 24, 2006 | 06:09 PM
T0R3D's Avatar
If that is a 7 inch wheel you shouldnt even be running a 33 12x50 on it. And I wouldnt recommend running a 36 13x50 on anything less that a 8-9 inch wheel, especially if your going to be offroading. It makes it easy for the bead to pop off when your wheel is to skinny.
Old Oct 24, 2006 | 06:18 PM
joez's Avatar
Uh, no. The bigger the difference between wheel and tire width the better the bead retention is. The 7 will hold the bead better than the 8, but will cause the tire to wear faster in the center and have more roll when driving on the street.
For a year and a half i ran an 11" wide tire on 5.5" wide rims without any issues. I put 22K miles on them in that time on the street, and it saw the trail on average twice a month. Even on my heavy K5 i had to run 18 psi on the street to get the TSL's to wear evenly, though, as they really wanted to wear the center with any more pressure than that. I was able to run 6-8 psi on the trail without any bead issues as well.
Old Oct 24, 2006 | 06:44 PM
titicaca's Avatar
thanks joez i thought that was right. the guys on pirate say its ok to do 35x15.5's on 8 inchers just wanted a second opinion. and you are right about the bead retention. the only thing is the tires will wear a little more on the road. like i said ill be off road mostly and the less air i can run the better. with a wider wheel youl need more air to keep the bead sealed. i was just curious if anybody had ran this setup and what kind of results they had.
do you think i would be better off with a radial type or am i ok with the bias plys?
Old Oct 25, 2006 | 01:14 AM
AH64ID's Avatar
You will be fine. It will take really low pressures to keep a flat contact patch on the street, but trail will be fine, just not optimal
Old Oct 25, 2006 | 03:01 AM
titicaca's Avatar
cool, im gonna get the tires first and put them on my 15x7s then ill get the 15x10's later. i can get them mounted for free so its isnt a big deal.
NCRidgeRunner
Aug 13, 2015 04:11 AM
priest16
15
Aug 6, 2015 07:43 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
