fj 80 coil springs and bj spacers
Old Oct 20, 2006 | 06:28 AM
workinprogress's Avatar
how much lift will a set of fj 80 rear coils,and bj spacers on the front of a 95 4runner, give me? will i need longer shocks? thanks
Old Oct 20, 2006 | 06:53 AM
Marc P's Avatar
It will give you about 1 inch of lift in the front with a stock bumper, the FJ springs will give you like 4 inches in the back. If you use short side Cruiser coils it might work pretty good..otherwise the back will be higher..
Mine with BJ spacers and Cruiser coils
Old Oct 20, 2006 | 08:41 AM
the reason i was asking is because im getting ready to purchase the coils and spacers,and i wanted to know if it was going to do what i wanted.i have 1.5" lift coils with 1.5"coil spacers in the rear,and i have the front cranked up to match.so basically all im wanting to do is use the bj spacers to ease off the torsion bars a little,and do away with the coil spacers in the back,plus maybe gain a little in the height off my ride.also im not sure if i need to install longer shocks?can anyone tell me if this setup would possibly work out for what i am wanting?is there any other hidden problems that i should be aware of before buying?any info would be of great help,thanks
Old Oct 20, 2006 | 11:39 AM
slosurfer's Avatar
did you get longer shocks when you installed the 1.5" lift coils and 1.5" coil spacers? I would imagine that if you did you would be fine. Also an extended brake line is needed if you don't already have one.
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
_Nicco_
Sep 21, 2015 03:06 PM
JHalcyonM
Sep 14, 2015 01:10 AM
Aaron Logan
Sep 3, 2015 08:08 AM
