fj 80 coil springs and bj spacers
Old 10-20-2006, 06:28 AM
workinprogress's Avatar
how much lift will a set of fj 80 rear coils,and bj spacers on the front of a 95 4runner, give me? will i need longer shocks? thanks
Old 10-20-2006, 06:53 AM
Marc P's Avatar
It will give you about 1 inch of lift in the front with a stock bumper, the FJ springs will give you like 4 inches in the back. If you use short side Cruiser coils it might work pretty good..otherwise the back will be higher..
Mine with BJ spacers and Cruiser coils
Old 10-20-2006, 08:41 AM
the reason i was asking is because im getting ready to purchase the coils and spacers,and i wanted to know if it was going to do what i wanted.i have 1.5" lift coils with 1.5"coil spacers in the rear,and i have the front cranked up to match.so basically all im wanting to do is use the bj spacers to ease off the torsion bars a little,and do away with the coil spacers in the back,plus maybe gain a little in the height off my ride.also im not sure if i need to install longer shocks?can anyone tell me if this setup would possibly work out for what i am wanting?is there any other hidden problems that i should be aware of before buying?any info would be of great help,thanks
Old 10-20-2006, 11:39 AM
slosurfer's Avatar
did you get longer shocks when you installed the 1.5" lift coils and 1.5" coil spacers? I would imagine that if you did you would be fine. Also an extended brake line is needed if you don't already have one.
punks_is_4x4
05-31-2016 06:03 AM
choppe777
05-16-2016 08:00 AM
_Nicco_
09-21-2015 03:06 PM
JHalcyonM
09-14-2015 01:10 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: fj 80 coil springs and bj spacers
