Anybody runnin' Warn bumpers?
ve been lookin' at these for quite awhile and they look awesome but I have never seen one in person and never seen any pics showing how they mount?
http://item.express.ebay.com/Vehicle...mdZExpressItem
Picture Link
Picture Link
Installation PDF w/ mounting pics from the Warn website...
http://warn.iwebcat.com/imgVD/WAR/68466a0-pn68450.pdf
a guy wheeled with a while ago has a warn bumper on his 2nd gen runner, but it doesnt have the hoops (which im kinda partial to just coz theyre so cool
). the thing is stout. seems to have a bit thicker material than my ARB. holds a laydown style winch and an upright i think, by the size of the top gap. his had an M8 in it. didnt have a chance to check out the mounts, but im sure it being a warn, would be sturdy enough. some pics:
hope this helps some...
Thanks for the pics -- now I know atleast one person is runnin' these --If ya don't mind next time you see it would you mind mentally comparing it with the ARB -- And then maybe sharing your thoughts on what could be improved on either ----other than the hoops (those are optional on either)
Thanks, Travis
Thanks, Travis
Are you sure you can get the ARB w/out hoops? Never seen it advertised or on the truck.. you can get a TJM without the hoops thou....
Couple things I notice different than the ARB. Cant comment on thickness... but mounting to frame appears similar, 14 bolts WARN and IIRC my ARB has 16 or 18. Both bolt to the same spots, the thing I like about the ARB is the triangulated metal that bolts to the bottom of the frame to support heavy winch loads, but makes SAS a pain. The other thing that looks benefical to the ARB is that the winch feet mount in a vertical plane instead of horizontal. This is adventagous since when winching the mounting bolts do not support the winch load, the bumper does and the winch is being sucked into the bumper.
The only thing I would improve on my ARB is the streangh of the shackle mounts. One the 86-95 bumper all they did was tack weld a washer around the metal which I think is 3/16". If I were keeping my truck I would be having some 1/4" welded in there.... On a side not the mount is MUCH stronger on the newer bumpers.
The ARB has been a fantastic bumper, strong, functional, and looks really good..
What makes the p/u different than the 4runner? I have had both and they were identical... in fact the front suspension on my 92 is from my 95 runner, and the bumper was on the 95....
for 600 shipped it looks better than arb, and cheaper, id get it. personally im gonna build my own or get this one, ive never seen it before, ive only seen the warn grille guard dee zee look a like thingys.
According to him, Warn said the mouting points are different on the frames.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Scotttekoch
Sep 28, 2015 10:30 PM
Toys4parts
Sep 26, 2015 01:56 PM
