calling all gear guru's hows this look?
heres the first mesh test with the marking paint. looks pretty good to me. im not an expert but any feedback is appreciated. im thinking it may possibly need a .002" smaller pinion shim what do you guys think by the pics?
heres the coast side
and the drive side
and the drive side
i took out .002" on the pinion shim and the pattern was more towards the heel this time so i went with it, put the solid pinion spacer in with 2 thick shims, torqued it down, the bearings were preloaded a little bit too much so i added another thick shim and did it again, the pinion moved alot more freely this time with no loosness and no binding so i went with it and dropped in the carrier in , set the bearing preload and then set the backlash to .008" , so at any rate its in the housing and the birfs are in. gotta finish the knuckles , hubs and the brakes, then on to the highsteer arms and the power steering pump.
Jun 1, 2021 01:51 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
Jnkml
Jul 6, 2015 01:20 PM
