calling all gear guru's hows this look?
Old Oct 13, 2006 | 08:10 PM
titicaca's Avatar
heres the first mesh test with the marking paint. looks pretty good to me. im not an expert but any feedback is appreciated. im thinking it may possibly need a .002" smaller pinion shim what do you guys think by the pics?
heres the coast side
and the drive side
Old Oct 14, 2006 | 03:59 AM
SlightlyModified's Avatar
no pics
Old Oct 14, 2006 | 05:53 AM
titicaca's Avatar
anybody else having trouble seeing it? btw modified i grew up in moraine, ohio i have a good buddy that lives in hamilton too. or i should say, hamiltucky
Old Oct 14, 2006 | 09:39 AM
deserttoy84's Avatar
pics work.
Old Oct 14, 2006 | 09:41 AM
phorunninduke's Avatar
pics work/
Looks okay to me. However I don't know if trusting me is the smart way to go, I don't have a lot of exsperiance setting them up.
Old Oct 14, 2006 | 04:27 PM
titicaca's Avatar
i took out .002" on the pinion shim and the pattern was more towards the heel this time so i went with it, put the solid pinion spacer in with 2 thick shims, torqued it down, the bearings were preloaded a little bit too much so i added another thick shim and did it again, the pinion moved alot more freely this time with no loosness and no binding so i went with it and dropped in the carrier in , set the bearing preload and then set the backlash to .008" , so at any rate its in the housing and the birfs are in. gotta finish the knuckles , hubs and the brakes, then on to the highsteer arms and the power steering pump.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
AaronM
Jul 8, 2015 07:15 PM
Jnkml
Jul 6, 2015 01:20 PM
