Big Tires On A Stock 95 4runner
They dont make 33x10.5 for a 16" wheel. You could run a 285/75/16 which would be about a 33x11.5 or a 265/75/16 which would be about a 32x10.5. It depends what backspacing the wheels are though, with a 285 you would need a small lift. I think you could get away with no lift and 265's if you wanted to go that route. I'm sure others will chime in. I run a 32x11.5 with about 3.5-3.75" backspacing and I rub at full lock going in and out of my driveway. If I ran those tires on stock backspacing I'm sure I'd be fine.
sniff sniff.... smell that..... yep its a newbie fest
use that button labeled search.. you will find your answer, many many many, and a few more times....
31' were a stock option, but 31's come on a 15" rim....
And whats with all the 33" talk, he asked about 31's... read the post then reply...
thanks for the input fellas, i am running 265/75 16 on it now. with no problem. so i guess my question was answered. okay i got another newbie question, what is the backspacing , some of you mentioned????
Originally Posted by craw4x4
hey all
Originally Posted by rocket
Originally Posted by chickenlover
Backspacing just tells you how much the tire will stick out past the fenders, or how sucked in it will look. The lower the backspacing, the further the tire/wheel will stick out. If you had a backspacing of 0 the hub of the wheel would be inline with the lip of the rim. So your truck would look ridiculous having your wheels stick out so far.
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
How does this help the original poster?
