Stupid question about oil filters
Old Oct 1, 2006 | 04:39 PM
bodo's Avatar
I just hit 500 miles on my rebuild and when I changed the oil and filter no oil came out of the filter. My old motor would pour oil down the side of the block when you pulled the filter off. Oh yeah it's a 22re.
Old Oct 1, 2006 | 04:52 PM
eric-the-red's Avatar
What brand of filter was on it, if it didn't have a anti-drain valve the oil could have just drained back into the sump.
Old Oct 1, 2006 | 05:11 PM
bodo's Avatar
Fram ph3614 I don't think the yota filters leak down the side but I was worried with the new motor and all. If this is normal I'm glad no more messy oil changes.
Old Oct 1, 2006 | 05:23 PM
Elton's Avatar
do not use fram or bosch
Old Oct 1, 2006 | 05:25 PM
DeathCougar's Avatar
I second that. Use factory oil filters. They cost almost the same.
Old Oct 1, 2006 | 05:26 PM
Elton's Avatar
ive used oem filters for awhile then switch to napa gold
Old Oct 1, 2006 | 05:43 PM
mr toytech's Avatar
it dont matter what oil filter you use it will drain back if it sits long enough before you take it off. but, i agree w/ elton, do not use fram or bosch. i have seen frams take out an engine from the paper eliment coming apart and clogging oil passages.
Old Oct 1, 2006 | 05:47 PM
bodo's Avatar
I normally use Wix but they were out and I didn't think it would hurt for a 500 mile oil change. I now have some yota filters and that's what's on there now.
Old Oct 1, 2006 | 05:56 PM
mr toytech's Avatar
wix is okay. but i would use factory if possible.
Old Oct 1, 2006 | 07:15 PM
bodo's Avatar
I've got yota filters now. So what I'm reading is the filters aren't supposed to leak oil down the side of the block so I'm cool.
Old Oct 1, 2006 | 07:35 PM
toy283's Avatar
That isn't necessarily what you're reading into it (or shouldn't be at least). Filters with a good anti-drainback valve (OEM, Wix, Motorcraft) will retain oil in the filter longer than those with poor ones (Fram, Bosch). Ideally, the oil would stay in the filter forever and then leak out all over your block when changed. This is not an ideal world though so view it as good when the oil leaks and bad when it comes off dry (unless the engine has been sitting for a couple days or more).
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
