GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
CB and antenna instally in my 05 Tacoma
Old Sep 18, 2006 | 08:06 AM
sake bomb's Avatar
Hey all. I don't post too much on yotatech but thought I'd share my CB install with everyone. I had seen this radio installed in the older tacomas and it was a nice fit so I figured I'd try it out on my rig. It took some 'slight' modification to my dash kit (ie: it was a major pain in the ass) but the final result turned out OK. Here's a few pics:
Cobra 18WXSTII radio
Firestik II antenna
Firestik side body mount
This one shows how I made the ground connection behind the tail light. I sanded the area under one of the fender bolts down to bare metal and attatched it to the base using 10 guage wire.
The coax is run along with some other wiring to the front of the bed and enters the cab through a grommet located behind the drivers side storage compartment. From there I ran it under the carpet and up through the center console. It was a tight fit and all 18 feet of the cable got used. Hooked everything up to the swr and after some fine tuning I'm getting 1.1 across the board, so all is well.
Old Sep 18, 2006 | 02:40 PM
rocket's Avatar
Nice install...I have the same CB waiting to go in the same location. I like your antenna placement too...looks good!
Old Sep 18, 2006 | 02:44 PM
Corey's Avatar
Co-Founder/Administrator
Looks very good :bigclap:
Very clean setup.
Old Sep 18, 2006 | 07:00 PM
xcmountain80's Avatar
Damn thats super clean!!!
Aaron
Old Sep 18, 2006 | 07:07 PM
wjwerdna's Avatar
looks nice.... i like the fullsize (1 din) cb install... ashstray (in 3rd gen 4rnr) is cool too, but kinda hard to see display... good work!
Old Sep 25, 2006 | 03:00 PM
cackalak han's Avatar
That antenna mount looks OEM. Good job. How is the reception with the current placement?
Old Oct 26, 2007 | 03:47 PM
steanson's Avatar
Sorry to dig this up again, but I was going to use the firestik sidemount that you used (looks GREAT, BTW), but was on the firestik website and they only recommended that mount for 2'-3' antennas...have you had any problems with yours? It appears to be a 4', no? Thanks for any advice. If anyone else has used this mount I'd love to hear from you..there is a 4Runner out there that gave me the idea but I can't seem to track his thread.
Old Oct 30, 2007 | 08:48 PM
skrassow's Avatar
Well I know this is an old thread, but...your install looks real clean, but I would advise againt doing the ground the way you did. Ive never installed a CB before so I guess I dont really know if its possible to ground elsewhere, but it looks like you are asking for rust problems down the road . With having it sanded down to bare metal like that it wont take long, espacially back ther where moisture tends to build up.
Old Oct 30, 2007 | 08:51 PM
CJM's Avatar
CJM
You must sand to bare metal to make a good ground. Or get the same kit I did with the no ground option.
Old Oct 30, 2007 | 09:09 PM
Prophet_MX's Avatar
agreed if you want a good chassis ground with low resistance you need to sand to bare metal. If you're that worried about rust you can always paint over it after its bolted.
Old Oct 30, 2007 | 09:15 PM
CJM's Avatar
CJM
Indeed, mine is actually grounded to my tool box-either way is bare metal.
Old Nov 2, 2007 | 03:10 PM
skrassow's Avatar
Yeah, I understand about the ground, but if you sand to bare metal like that it WILL rust. I definatley would have painted over it if I couldnt find a way to ground inside the cabin. Ir find a factory gounding point, such as alt/batt to frame.
If he leaves it like it is, he will be battling rust real soon.
BeMiceElf
Oct 10, 2015 09:40 PM
TDonkey
Jul 26, 2015 10:14 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jul 23, 2015 11:20 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
