Transmission Cooler 2002 4x4 Question
Old Apr 18, 2003 | 10:58 AM
hudsonasmith's Avatar
I'm preparing to install an auxiliary automatic transmission cooler.
Which line is the return line to the transmission from the radiator cooler? I have seen some posts for cooler installations for older vehicles that indicate that it is on the drivers side of the vehicle close to the big radiator hose. Is it the same for a 2002 4x4?
Thanks,
Hudson
Old Apr 18, 2003 | 11:05 AM
HBoss's Avatar
Will most likely be on the driver-side of the rad, but some 4Runners (I.E. a '98 2WD 2.7L) may have it on the passenger-side. I'm not sure exactly how many & which models definitely have it on the passenger-side though...
Tranny Cooler Installation Link
Old Apr 18, 2003 | 11:15 AM
jacksonpt's Avatar
Senior Member
I have a pretty detailed writeup on my cooler install (96 SR5 4x4 V6)
Old Apr 19, 2003 | 05:18 AM
Thanks for the information. It confirms my observations and my search results. The '96 pictures look a lot like my 2002 as a matter of fact.
Old Apr 19, 2003 | 07:11 AM
WATRD's Avatar
I just installed the mother of all transmission coolers, from a class A motorhome towing up to 10,000 pounds and can confirm that Jackson's diagram is correct for my 2001 Tacoma anyway.
Old Apr 19, 2003 | 10:42 AM
WATRD
Thanks for the confirmation.
I'm also installing a non-toyota cooler with a higher capacity (24,000 total weight rating) and that is why I had to ask the question. I suppose that if you buy the $238 TRD cooler instead of the $70 aftermarket with greater capacity, then you get the "instructions". I always like to get more for less.
mskalmus
May 28, 2017 07:51 AM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
