View Poll Results: Should I buy a tow strap with:
"loop" ends
69
88.46%
"hook" ends
9
11.54%
Voters: 78. You may not vote on this poll
Tow straps
Tow straps
Give me your opinions on tow straps. What are the pros and cons of loop ends vs. hook ends. I need to buy a new strap and wonder if anyone has strong feelings either way. I can't seem to make up my mind. I do not have any shackles on my truck, by the way.
If a strap breaks with a loop end, there's no risk of injury. The straps with hooks can become deadly projectiles. The hook ends are designed for towing, not a recovery strap for a stuck vehicle.
Both.
Use the one w/hooks for light vehicles and such and for towing, but never for a vehicle that's stuck bad or the hooks could become a weapon. This is good if someone is just a little stuck and could use a pull/push to get the tires back on the ground or whatever. The ones with hooks, in this case, are fast & easy to use and they normally only need to be moved a meter or two. It's also good if they don't have D-ring shackles or open tow hooks. I've pulled a few stuck cars out of deep snow and they only weigh about 3000 lbs. at most. A recovery strap would have been useless as these cars don't come w/open tow hooks.
Recovery strap for the obvious: serious recovery. If they are "seriously" stuck, they should have thought they may get in that position and have open tow hooks or D-ring shackles. If not, they should have thought ahead...
I bring a tow strap (hooks), recovery strap (no hook) and spare D-ring shackle for those who have nothing but frame holes.
When you guys use recovery straps with loops at the end, and the vehicle doesn't have a "tow hook" on the front or back, how do you connect it to the stuck vehicle? Basically, I'm asking if you make some sort of slip knot, or what? Just curious. Thanks-
CTB
CTB
CTB
CTB
CTB
CTB
If it's you without tow hooks, get some! They are cheap and easy to install.
Originally posted by upndair
You don't go wheeling with guys who don't have tow hooks on the front and back. If you do, let the guy without the tow hooks hook up his own end.
I think its time for me to get some non-hooked recovery straps!
You don't go wheeling with guys who don't have tow hooks on the front and back. If you do, let the guy without the tow hooks hook up his own end. That way when you pull his bumper off or bend his his tie rod, it's not your fault.
Alright, now a question about tow hooks...
I just have the single factory tow hook in the front, and nothing in the rear (except for the factory hitch). Should I try installing another hook on the front, as well as one or two on the back, or should my current setup be sufficient?
If so, where should I look to purchase the hooks, and where should they be mounted? I haven't looked to see if there are any good stock mounting locations yet, sorry. Thanks for the info fellas-
CTB
CTB
There are a couple of small holes in the back that you could put a shackle through, or the big hoops under the rad.
Rear Passenger
Rear Driver (above exhaust pipe - sorry bad pic)
Front Passenger
Front Driver
Rear Passenger
Front Passenger
Front Driver
Hey Cebby,
So, you think a shackle would work in that hole in the "rear passenger" picture you posted about? Do you think it would matter if the shackle had any play in it, or would the center shaft of the shackle need to fit through that hole really tightly? (haha, really sorry if that sounds like sexual innuendo, not meant to
Co-Founder/Administrator
CTB
CTB
It looks by Cebby's last two pics you could use a D ring shackle on the front where those holes are, but I am not sure of the strength of the mounting brackets.
You certainly don't want a shackle to break at that mounting point and end up becoming a deadly projectile.
The front holes are a separate bolt-on piece. They bolt into the frame with a 1/2" equivalent bolt. This is also how the factory tow hook is on also though.
The rear tabs are welded on. Not sure of the hole size in the back, I'm in a suit and don't want to roll around on the ground to measure it.
The way that plate hangs down in the back, there is probably a chance it might bend if the tugging gets violent, although is is about 1/4" thick, runs up the side of the frame rail and has a nice bead holding it on. I think the shackle "should" be snug, but it probably isn't critical. I doubt there is possibility that it would break.
I'm ordering some shackels soon. If that hole is too big, I'm going to weld an insert into it to beef it up cause I want to leave my shackle on (without rattling)
Now that it's nice out, I can finally break out the
CTB, if it's too loose, they have pills for that now...
Cebby, if you want some shackles that will stay nice and not need paint, check out "Off Road Only" in the Vendor section.
They have nice stainless steel ones that are not much more than a standard one.
Corey, how often do you need to paint your shackles?
