3.4L Timing Belt Issues
Old Aug 20, 2006 | 03:25 PM
thefallman's Avatar
i have 3.4L that i am swaping into a 89 x cab. The issue is i got it from a Wrecking yard it was hit in the front end and broke the tensioner, so the wrecking yard cut the timing belt. they also turned the engine over and camshafts.
So i have No idea where the camshafts should be i set them to the timing marks but there is a possiblity of having the right bank 360degrees off from the Left bank so that the timing would be completly screwed any ideas on how to solve this???
Old Aug 20, 2006 | 04:27 PM
Firefightertaco's Avatar
This should help. http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old Aug 20, 2006 | 05:43 PM
MTL_4runner's Avatar
Originally Posted by Firefightertaco
If that doesn't get you back on track then this should be enough to put you over the top:
http://www.lieblweb.com/tacoma/Mecha...cans/index.htm
Old Aug 20, 2006 | 05:55 PM
seanz0rz's Avatar
Guest
wow, some great info there. that will really help when i do mine in another 70k miles
Old Aug 20, 2006 | 09:03 PM
thefallman's Avatar
Okay so i feel like a complete idiot now. After i read those 2 links i realized something it is imposible for the cams to be out of alignment by 360 degrees because they rotate at half the speed of the crank so for every 2 revolutions of the crank they rotate once so they could be 180 degrees out but not 360. and if they were 180 out you would know because the timing marks wouldnt line up. they would be 180 degrees off on the cams only. so if you line up the timing marks your all good
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
colinmil
Jul 6, 2015 04:03 PM
