4.3 V8 Swap
4.3 V8 Swap
I cam across a stellar deal on a complete wrecked sc430 with motor wireing...everything...i have been checking some other forums about a swap into a 1995 4 runner 5 speed...havent found a lot of info on the wireing issue if anybody has some insight i would appreciate it...
thanks
thanks
https://www.yotatech.com/forums/f161/1uzfe-swap-into-2nd-gen-4runner-54771/
cebbys swap
http://lextreme.com/forums/
everything you could ever want to know about uz series swaps. i think personally you will find the wiring part easier if you go with a obd1 4.0L 1uzfe from a sc400 or ls400.
http://www.lextreme.com/
http://www.1uzfe.com/
http://www.v-eight.com/
http://www.intellexual.net/
http://geocities.com/deonsv8hilux/ read this link!
http://www.boosted4runner.com/index1.htm this one too!
http://www.planetsoarer.com/
that's every relevant website Ive been able to find about uz series, that i feel are informative, but I'm sure there are more, webs a big place. you will have to fab engine mounts, if yours is a 5sp, you will need a bell-housing adapter(dellows or another one, cant remember name, both from australia/new zealand) if you go auto and still want 4wd, you'll have to do what cebby did(put some of the uz series tranny internals into the 4runner tranny. its quite a complex swap in some regards, space is also a big issue. you will most likely have to go with electric pusher fans for the radiator, there is very little room between the radiator and the front of a uz once mounted.
hope this helps, brad
cebbys swap
I have been following the swaps very closely but the person with the car said i could probably pick it up for like 500-1000 for everything it was hit on the side so i am completating doing this swap since that is the bulk of the fees.(i think)...
pplusent
Sep 18, 2018 10:02 PM
Fahrenheit 451
Feb 6, 2003 08:38 PM
