22RE Piston to cylinder clearance
I am about to rebuild my engine with my kit from Engbldr.com. I did not bore it out as the cylinders looked good. When I put the pistons in the cylinder with no rings on them I can rock them back and forth the same way the crank would. The book says max .035 mm clearance which is next to nothing. When I measure, I get a clearance of .10 mm, bore size is 92.5 and piston size is 92.35.
Anyone with any experiance let me know what you think. Will I have some slap. We are talking parts of a mm but when I hold the piston in the bore it seams like a lot.
mine are loose as a goose on my 22RE. there was still a very visible crosshatch all the way around the cylinders(not egged out) when i tore it down, so i reused the pistons and just put in new rings. i could definitely rock the pistons back and forth a bit on all cylinders, but it runs fine and doesn't make any piston slap noises. remember, your pistons expand when they're hot. just my .02.
In most of the 22Rs I've done HG jobs on, the pistons weren't sloppy at all. There was one I did that the pistons we're sloppy like that, I ended up tearing it apart and the cylinders we're worn at an angle, and the piston skirts we're cracked, and I imagine would have fell off if it were driven much longer.
Sep 4, 2015 09:27 AM
Backcountry411
Jul 24, 2015 08:06 AM
