inner/outer tie rod removal ?
Old Jun 7, 2006 | 08:46 AM
Foch's Avatar
Hope this makes sense, but is it possible to disconnect the inner tie rod from the outer tie rod without first disconnecting the outer tie rod from the knucle arm?
I need to replace the tie rod boot on my 98 4Runner and it would be alot easier if I could just leave everything attached and just disconnect the tierods.
Thanks in advance.....
Old Jun 7, 2006 | 10:16 AM
MTL_4runner's Avatar
You need to remove the nut and detach the outer tierod from the spindle (far right) before the inner tierod (far left inside the steering boot) can be unscrewed. Then you can cut the clamps, pull back the boot and remove the inner part of the tierod. The issue may be that you need to unscrew the inner tierod from the adjustment collar because the smaller end of the boot will not fit over the inner tierod. I don't know since I have not had to do mine.
Here's the pic (thanks Bob!):
Old Jan 4, 2010 | 11:35 AM
semperfi96's Avatar
DUDE thanks, I have to do this, this weekend!!
stoneboy91
Apr 5, 2016 05:17 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
I8URSVT
Sep 3, 2015 11:42 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
