leaf spring centering bolt???
Old May 7, 2006 | 06:11 PM
richboss302's Avatar
Question leaf spring centering bolt???
I want to remove the 1 inch helper/add-a-leaf spring and the top of the bolt that sticks/drops down through the leafs is ROUND. How do I remove the nut on the bottom of the bolt on the underside of the leaf spring without the bolt spinning/turning as I try to loosen the nut??????? Do I have to use vise-grips or something simular?? The head of the bolt is not hex shaped like a normal bolt, it's round??
Thx,
Rich
Holiday, Florida
Old May 7, 2006 | 06:25 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
vice grips.
if worse comes to worse you can file some flat edges on and use an adjustable crescent wrench
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 21, 2015 08:22 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
