3vze pointers
Old Apr 19, 2006 | 08:51 PM
3vze pointers
Im getting ready to pull the heads on my 3vze. Any pointers on this? I pulled them when I worked at the dealership but it's been 5 years since I've really worked on one of these engines. I assume start with taking the intake off and go from there. Any tips here guys?
Old Apr 20, 2006 | 05:28 PM
Elvota's Avatar
Look here for steps:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Be sure to mark your vacuum hoses in such a way that it will be easy to put back together. By new head bolts. Do not re-use your old ones.
Engnbuilder or Partsdinasour are a great place for parts and more.
Also, do a search and you'll find a lot of tips on removing the crankshaft pulley bolt, cam pulley bolts and other tricky things along the way.
Best of luck.
Old Apr 21, 2006 | 06:46 AM
Radyota's Avatar
Loosen the exhaust crossover pipe and remove the nuts from the driver's side. That way, you can pull the driver's side head with the manifold attached and remove it later. Then the passenger side head can be pulled with the manifold and crossover. They are much easier to remove from the heads outside of the engine bay.
Replace the knock sensor wire if it's looking "iffy". Good luck!
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Chicken12
Oct 14, 2015 03:54 PM
Matthew Perez
Sep 28, 2015 05:43 PM
