Hilux LSD diff installed now vibration
I got a Hilux LSD diff for my 90 4runner with 4.88's. We installed it now I have a vibration up until around 25 mph its not as bad with the clutch pressed in coasting. & gets worse when I accelerate harder in the mph range.
Everything is tight I flipped the driveshaft 180* & no change. The diff has fluid we checked it today.
I have searched & have not found a problem like mine with a solution. Other then the diff having a prob is ther anything else that I could check?
Thanks for any ideas :pat:
I spun the pinion around before we put it in & it was fine. I put Lucas 90w & added one tube of LSD additive when I filled it up.
I have not taken the driveshaft out & driven it but I will in a few mins to see if that does anything. I am going to spin the shaft on the splins on the transfere case to see if that helps.
& yes the tires are the same on both sides.
no a friend & I did the install.
I figured it out what was going on. I spun the driveshaft on the transfer case & the vibration is down to a very min. its all good
thanks for the help though
jerusry
Oct 19, 2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
