Engine Hesitation, whats happening?
Old Apr 13, 2006 | 06:45 PM
LS1Steve's Avatar
Running fine, then pulled off to have some fun in the mud, pretty bumpy (harsh bumps) and a few puddles. Played for about 3min, then pulled back on road. Now the truck hesitates when under any more load than about half throttle. I got on the freeway fine, felt a little less power. It would get up to speed fine and hold any rpm smoothly, but when i push the throttle down, i'd feel some jerkiness to the acceleration. Every now ant then it would cut out and drop the rpm 300-400 then return to normal. Definitely only under load. Seemed to have gotten slightly better after 10min, but still there. I popped the hood and nothing really got wet, distributor/filter/wires all stayed dry.
What the heck is going on??
feels worst when starting out in first gear, then its fine for the rest of first, also when at a low speed but in a high gear so its kinda lugging, hesitates badly.
Old Apr 14, 2006 | 11:02 AM
Bobakazi's Avatar
Are you sure some water did not get by your air filter? Maybe it had dried out by the time you looked at it? How is it now that it has sat overnight?
Old Apr 14, 2006 | 01:16 PM
AH64ID's Avatar
I agree sounds like symptoms of H20
Old Apr 14, 2006 | 02:59 PM
tc's Avatar
tc
Or mud clogging the air filter.
Old Apr 14, 2006 | 07:41 PM
LS1Steve's Avatar
not water in filter, i checked and it was completely dry. next morning, not quite as bad, but still hesitating bigtime. I was able to make a 200 trip home so any water anywhere had to be evaporated. still doing it. worse when cold.
i picked up a cap/rotor, plugs, fuel filter, air filter, and some seafoam. i'll give all that a whirl tomorrow morning and see what happens.
Old Apr 14, 2006 | 11:16 PM
AH64ID's Avatar
Next guess would be water/mud in the distro....hopefully changing those helps
Old Apr 15, 2006 | 10:44 AM
LS1Steve's Avatar
well, changed the plugs/cap/rotor and that seemed to fix it. rotor was pretty fugly, i just don't understand what happened to make it hesitate all of the sudden. oh well, problem solved.
Old Apr 15, 2006 | 11:03 AM
AH64ID's Avatar
Could have just been a coincidince....
I was out wheeling one day, and at the same time my exhaust wraped around my axle, and my cap/rotor melted. I thought it wouldnt start because of the exhaust being clamped shut, so I had my buddy pull it straight with his truck and removed it at the cat...still wouldnt start. Started playing around, I was getting fuel, and no spark.. So I took the cap off, FUGLY... It was just weird that I did both at the same time.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jonny246
Jul 12, 2015 04:51 AM
jon.r
Jul 11, 2015 03:34 PM
88runnergomas
Jul 9, 2015 01:12 PM
colinmil
Jul 6, 2015 04:03 PM
