315's...do you run a power steering cooler?
Although I don't have a 3rd gen, I did this mod awhile back using the same item from the same place too! Installation wasn't that bad except for finding the right sized tubing that fed to the power steering resevoir. I did mine just more of peace of mind since I went up to 35's as well.
Good luck!
Good luck!
seems like there is alot of interest for tranny/power steering cooling systems.. someone needs to fab a high quality kit, and setup a group buy!
out of curiosity where do you plan to mount the cooling core?
There is enough room to mount a Hayden 678 transmission cooler in front of the radiator. If this power steering pump is small enough, you could probably mount it next to the tranny cooler.
I was just thinking about it, but, even the return like for the PS is a hardline. Are you guys going to cut it and run a rubber hose? Or what?
Hmmmph. I could have sworn it is a hardline. Oh, it goes to rubber towards the pump eh. Okay.
Yeah, you guys make sure you DO NOT cut that pressure line... oh my god, I did that once when I got happy with a sawzall and it was not a fun experience.
Yes, there was a 200ft cliff nearby and I was about to jump off.
Jun 1, 2021 01:51 PM
skoti89
Jul 8, 2015 12:05 AM
