Correct idle RPM for 22RE
just purchased a '93 yota 4x4 and am currious about the idle. It seems to be idling at too high of an RPM - it's around 1,200 - 1,400 at idle. Any insight into what the proper idle speed should be?
Thanks much,
Josh
Thanks much,
Josh
The manual calls for 750-950 RPM. 750 is a tad rough so I set mine at 800. Anything over 950 and you get problems with a fluctuating idle (usually with the bakes applied) because the computer is trying lower the RPM's and lean out the fuel mixture. Toyota programmed this as "deceleration fuel cut-off." Saves gas and lowers emissions.
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
