mounting 3vze to engine stand
Old Mar 31, 2006 | 06:52 AM
motoracer47's Avatar
i know this info is in here somewhere, but i cannot find it! i dont know if im not wording my search properly, but anyways, does anyone know what size bolts i will need to mount a 3vze to an engine stand? i dont have any bellhousing bolts with it to measure from, basically just the block and crank.
thanks, brad
Old Apr 2, 2006 | 07:31 AM
anyone?...................bueller,bueller,bueller?
Old Apr 2, 2006 | 08:04 AM
dwh91102's Avatar
I used my tranny bolts (bellhousing bolts) with some washers, worked fine for me.
Old Apr 2, 2006 | 09:06 AM
Tragic Drive's Avatar
I believe its 12mm X 1.25 thread I dont know stand you have so your length may vary .If you get them from ACE hardware the part number is MHCB-12FG those are the ones I used.
Old Apr 2, 2006 | 08:32 PM
awesome, thanks! yea, i didnt have any bellhousing bolts as i got just the block/crank/pistons, and its in a crate, flywheel side down, was hoping to get the size before renting the hoist to get it out and put it on the stand. thanks again, brad
Old Apr 2, 2006 | 11:05 PM
Vrooooom's Avatar
I used M12x1.25x80mm bolts to bolt up a 5vz engine to an engine stand. 5vz and 3vz engine blocks should be the same.
Old Apr 3, 2006 | 04:00 PM
sweet, i was thinking 70-80mm length would work, ill make sure and have plenty of washers just in case. thanks again everyone, hopefully I will be able to rent the hoist tomorrow, it was out this weekend and today.
razorman8669
Jul 12, 2015 12:13 PM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
