Transmisssion Cooler Leaking into radiator?
Old Mar 22, 2006 | 10:43 AM
dibble9012's Avatar
Have any of you had this problem? I noticed today that I had transmission fluid leaking like you wouldn't believe, took it in to the shop, and they said the transmission cooler is cracked, but that I am lucky that the anti-freeze is not in the transmission. They also said this is the 2nd 4runner they have seen with this problem, so its really just a fluke. Wasnt planning on spending 600 bucks right now :cry:
Old Mar 22, 2006 | 10:45 AM
kmcc78240's Avatar
how would antifreeze get into the transmission??
Old Mar 22, 2006 | 10:49 AM
dibble9012's Avatar
because the transmission cooler is broken inside the radiator, it could pump in antifreeze instead of transmission fluid
Old Mar 22, 2006 | 10:54 AM
eric-the-red's Avatar
Because the transmission cooler is in the bottom of the radiator. When the engine is running there is pressure in the cooler so transmission fluid leaks out, but when the engine is stopped there's no pressure so coolant can get into the cooler.
dibble, why is it $600, a new rad is about $200 and labour shouldn't be much more than 1 hour to change it.
Old Mar 22, 2006 | 10:55 AM
Beat me to the answer, I've got to work on my typing speed
Old Mar 22, 2006 | 10:57 AM
dibble9012's Avatar
I guess labor? Plus they have to replace ALL fluids, and do a flush to make sure everything is clean.
Old Mar 22, 2006 | 10:58 AM
kmcc78240's Avatar
Well I learned something new sorry to bug you guys just sounded weird to me, eric does have a good point about the $$ though
Old Mar 22, 2006 | 11:04 AM
dibble9012's Avatar
it is high, but I trust the people there (I know them) and I can't really go anywhere else, it was really driving poorly on the way there, and it is my dd.
I guess its bad on my part to have just said yes and not research into actually the cost of everything, but as my only car, I desperately need it to run right.
Old Mar 22, 2006 | 11:09 AM
kmcc78240's Avatar
I hear that, you need to take care of your baby. I just drooped my saving into a head gasket, water pump , timing belt, plugs wires, coil pack, knock sensor, Valve job, Raditor, thermastat ($154 second gen though)ac compresor (south texas had to do it been to long without) I just didn't now about the transmission cooler, very interesing it will all work out though
Road Bull
Oct 10, 2015 04:55 PM
TJWilly
Jul 31, 2015 02:05 PM
this_guy
Jul 31, 2015 01:27 PM
Coreyr384
Jul 10, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
