New Yokohamas and AR's
Got my new Yokohamas 305/70-16 MT+ tyres and American Racing 10x16 rims.
I searched for a while but could not find the correct backspacing for my SAS. But since I'm running spacers anyhow I opted for the 10x16 wheels for the IFS axle. The rims still have a minimum clearance of 1/2" from the tie rod ends. The reason I did this was that I want to mount larger discs and calipers.
I really like the Yokohama's compared to the BF Goodrich and Cooper tyres I had before. The have a lot more grip in rainy conditions. Didn't have time to test them in the mud cause everything is still frozen over here.
Here's what it looks like now:
Never mind the missing rear bumper, I'm working on a new one with spare tyre carrier right now. Hope to finish it this weekend. I'll try to match the design I did on the front one.
Front shot:
I cut my front coil brackets and remove 3/4" of material and added a rubber 1/4" spacer between the coil and the bracket. The above pics are without the 1" lift.
Cleaned, salt and rust removed and I finally put on the rubber flaps. Only had the flaps in my garage for some 3 years so I thought I finally mount them before the rubber is corroded from age.
Sorry if some of the pics are large. I checked twice and they are all the same size
Front shot:
They are not on yet. These are '93 Hilux vented discs with '90 4R calipers.
These discs are 289x20 mm.
I got some large supra MKIV calipers (aluminum) which are for 320x30mm discs.
My local shop has a detailed book on brakes and I found that the yota HZJ80 from '92 -'95 have 311x32 discs. 6 bolt pattern so that should fit.
I'm still looking to find some bigger ones, maybe Tundra, but I cannot find any specs here on those.
The HZJ70 are 322x32mm but those are unfortunately 5 bolt.
If I'm really lucky the HZJ80 calipers are a bolt on swap. I guess I'm gone find out as soon as I score some.
And to top it off I plan on using the IFS hubs so I can remove the steel spacer and use them in the rear. The aluminum spacers in the rear allready have 1 crack.
TStango
48
Feb 2, 2007 03:02 PM
