hauling 1500 lbs in my 1st gen?
Old Mar 9, 2006 | 09:43 AM
mike_d's Avatar
today after work, i'm going to pick up some hardwood flooring for my weekend project (hopefully only weekend project and not a 2 week ordeal ). the guy at the store said that it'll be around 1500 lbs. i have a 1st gen 4runner with no back seats, and i should be able to fit it all in there, i'm just worried about the weight. i know that the pickup version of my 4runner are nominaly 1/2 ton trucks. what do you guys think about hauling 1500 lbs about 5 miles through town, i.e. no high speeds or large hills or long distances?
thanks!
Old Mar 9, 2006 | 10:33 AM
netgodsrdn2's Avatar
For a short trip like that I'd guess it'll be fine. I used to haul way more than that in my little 86 2wd PU much farther than 5 miles and I still got over 300k miles out of it with no troubles. Just take it easy and you'll be ok I think.
Ron
Old Mar 9, 2006 | 11:21 AM
89macrunner's Avatar
ive carried probably 1000lbs worth of stuff before and i was ok
Old Mar 9, 2006 | 11:52 AM
V_Runner's Avatar
Banned for stupidity
do you have aal's in???
Old Mar 9, 2006 | 02:33 PM
mike_d's Avatar
no, but i do have OME's 2" lift spring. the spring rate seems to be about the same as stock, they're just taller.
Old Mar 9, 2006 | 02:48 PM
ZUK's Avatar
ZUK
It should be interesting.....seems like the rubber snubbers would be bottomed out. Can you take a pic of it?
Old Mar 9, 2006 | 03:04 PM
Bobakazi's Avatar
I do construction, and I have put that much in mine several times. You probably will be riding on the rubber stops, but it should be fine if you take it slow over bumps. Distance and hills don't really matter, just watch for bumps.
Old Mar 9, 2006 | 03:09 PM
91_4x4runner's Avatar
I've hauled around 1500 pounds of people and stuff in my 4Runner before without any problems.
Old Mar 9, 2006 | 04:51 PM
mike_d's Avatar
actually, it wasn't too big of a deal - the ome springs must be variable rate or something becuase they feel good when i'm unloaded, but they were stiff enough to handle the load.
loaded:
unloaded:
sorry for the poor picture quality, but it was night and i was tired from loading and unloading the truck.
Old Mar 9, 2006 | 06:32 PM
Willcipher's Avatar
What size tires are you running there? That 2" OME rear spring lift looks taller than 2".
Old Mar 9, 2006 | 06:38 PM
photoleif's Avatar
just pump up the tires to a reasonable pressure -- my old ones called for 55 lbs with that kind of load -- to avoid slicing 'em up. i had no troubles at all with that kind of weight for a few miles. just as everyone said, just take it real easy -- it drives goofy with that much back there. it's a bit like driving on ice... you're fine if you just take everything 2x as slow as normal.
Old Mar 9, 2006 | 07:42 PM
F0RSAKEN's Avatar
Does anyone know the weight rating for after market springs? I installed AllPro 1.5" lift springs, but they came with no weight rating....
Old Mar 10, 2006 | 08:05 AM
mike_d's Avatar
they're 31x10.50's on 15x8 wheels. they look small because they're not a very agressive tire, they're the michelin ltx a/t. they came with the truck and i can't justify buying new tires while they're still good, but they wear like iron and just won't wear out.
i'll have to take some measurements to see how high the back really is, maybe it's more than 2", but ome said their springs were good for 2" above stock (which i guess looks like more because of the typical rear end sag)
runnermedic
13
Sep 21, 2015 05:20 PM
potatopants
Sep 15, 2015 06:26 AM
ToyotaMD
Sep 7, 2015 04:44 AM
joeynational
Sep 5, 2015 01:54 PM
Badfish740
Sep 4, 2015 04:21 AM
