square tubing long travel drive shafts
i was watching extreme 4x4 on spike tv this morning and they are building a '82 pickup into a rock buggy. when they were installing the drive train i noticed they used two pieces of square tubing that slide in and out of eachother with a ujoint welded on each end to make a long travel driveshaft. and i said wow this could save me a bunch of money on new driveshafts after i get my longtravel installed. are these reliable driveshafts? is this a good and common way of building them? rock buggy only or would they be too unreliable on my daily driver?
i have one in the front on the 4runner, its basically just a cheap way of getting tons of slip, the only downside is that they tend to be a little "clanky" and are hard to get perfect (mine vibrates a little above 40mph)
for the front, its perfectly fine if you have manual hubs (which you should) for the rear though, not so if its driven at highway speeds.
i run a square d-shaft up front, cheap to make and the d-shaft doesnt spin at all on the street so its fine.
Jun 1, 2021 01:51 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
