Rear suspension OME 890 or 891
Old Feb 9, 2006 | 09:50 AM
98T4R's Avatar
Hi Everyone, I'm new here. I have a 98 4 runner which I am looking to lift. This is my first modification. I have read alot about the Tundra coil lift and it sounds awesome but I am a little timid in trying it because I don't quite understand it. I decided on OME 882's on the front,for the height and I have a 110lb brush bar. In the rear I was thinking OME 890's or 891's. I want as much height as possible without the back end sticking way up in the air. I don't mind a little higher, an inch or so is fine, However I don't carry alot in the back so I don't want it to feel like I'm riding on concrete. I also don't want the rear to sag when I do load it up for trips. Can anybody help me out there.
Thanks for all your time, 98T4R, in need of lift
Old Feb 9, 2006 | 10:08 AM
Mr. Bob's Avatar
How tall are you looing to go????
This is the best lift out there:
http://www.sonoransteel.com/store_co..._liftkits.html
system 1 would be the one you would be looking at most likley....
If you look at all the stuff you get there, that is a deal!!!!!
Hope this helps!
Old Feb 9, 2006 | 10:11 AM
HOJU's Avatar
use 891's and don't forget the diff drop bracket. Before i had bumpers and such, I got about 3" out of my 882's and 3.5-4" with my 891's.....
I've had very a good experience with my OME, so good luck-
oh yeah, and I got my lift for under $550
Old Feb 9, 2006 | 05:33 PM
98T4R's Avatar
Ome 891's
Hi Hoju, I checked out the pictures of Betsy, she is beautiful. Do you carry much weight in the back of your truck. Is the rear end hard with the 891's. And, do you have a body lift on her aswell or is that just the 882"s and 891"s that allow 35's. Finally , is betsy 2wd or 4wd because she sure does look tall in the pictures.
Old Feb 9, 2006 | 05:39 PM
98T4R's Avatar
Hi Hoju, It's been a long day, I just read Betsy's stats, 2" BL.
Old Feb 9, 2006 | 09:58 PM
HOJU's Avatar
I've got a sub box and amp that are close to 150lbs plus that bumper pulled me down a little bit, and 4x4 of course-
Old Feb 10, 2006 | 09:11 AM
98T4R's Avatar
Hope this helps!
Hi Mr Bob, I'm looking to lift it about 2-2.5" up front and about 3" in the back. I like the slightly tilted look and the 4runner comes factory 1" higher in the back anyway, then when I load it with gear the backend will not look saggy. My problem is I would like to go with 891's in the rear but I don't want a harsh bumpy ride when I'm not carrying weight.
Old Feb 11, 2006 | 07:45 AM
MTL_4runner's Avatar
It won't be that bad with the 891s and if you really want 3" of lift in back that would be the way to get it (you could use spacers too). I have 881s in front and 890s in back so it may be close to the same up front if you are going with 882s and carry 125lbs extra on the front. It really is a tossup.....the biggest unknown is what final lift you are going to get up front. Maybe order both sets (890s and 891s) and then put in a set after you install the fronts. My hunch is that 891s would probably sit an 1" higher in the rear and the 890s will be very close to dead level (depends on what look you are after).
Old Feb 11, 2006 | 09:41 PM
potsy's Avatar
From: Ocean Beach, CA Five square miles surrounded by reality.
so your saying with 890's in the rear and 881's in the front you sit pretty much level?
Old Feb 12, 2006 | 02:20 PM
payyourtoll's Avatar
typically, yes. But depends also on what shocks you mount them with. If you keep the stocks my "yes" answer is out the window.
Old Feb 13, 2006 | 04:40 AM
The rear will still be about 1/2" higher, but it looks more or less level. Any weight up front and it will start looking like a drag racer. So 882s with any decent amount of weight should be level with 890s in back. The 891s will be about 1.25" higher in the rear but if you carry weight or tow, it will likely be sitting level. Again, depends what look you are after and if you will carry gear up front or in the rear.
Old Feb 13, 2006 | 05:17 AM
HOJU's Avatar
Here's my 4runner the day i got the lift put on. Because of my stereo in the back, it's sagging a little bit, IMO. But, that's 882's with diff drop and 891's with 10 trimpacker and HD shocks all around.
Old Feb 14, 2006 | 12:30 PM
Gerdo's Avatar
I was thinking of spacers but I'm starting to head toward OME front and rear.
I only want about 2" in front and 3" in back. I need to still get into a garage and this is all the room that I have between my rack and the opening.
Below is what I was told by an OME dealer.
I hear that the OME 880 will give me about 1.5"-2" in front, 881 for a heavy bumper/winch. And 906 or 890s if I tow alot and would give me 2"-3" in the rear. I was also told that I should not go with the 891s only if I was going to carry a constant load of 660lbs.
Who is the best and least expensive OME dealer?
Old Feb 14, 2006 | 02:01 PM
Gerdo's Avatar
Does anyone have any experience with the 880 and 890?
Old Feb 14, 2006 | 06:33 PM
I got about @1.5 - 1.75" in front (tough to measure) with 881s after they settled.
There are a few running 880s and 906s on here, but not many.
You might also read these if you haven't already:
https://www.yotatech.com/forums/f2/ome-specs-straight-ome-15450/
https://www.yotatech.com/forums/f31/suspension-lift-faq-44741/
From what I gather people with the 880s were getting about 1" of lift (vs 1.5+ with the 881s). You will definately have a visible tilt to the vehicle with 880s up front and 890s in the rear (alot of times you see people eventually put a 1" spacer in up front to compensate for the tilt later).
Old Feb 15, 2006 | 01:00 PM
potsy's Avatar
MTL, how do you like your setup, as far as suspension feel, etc.? i was thinking of getting the exact setup you have. if you had to do it all over again, would you get the same stuff?
Old Feb 16, 2006 | 04:44 AM
Yeah I absolutely would (but keep in mind I am not a hardcore offroad guy either).
It gave me exactly the look I was after, rides great and didn't break the bank.
Old Feb 18, 2006 | 08:41 PM
Gerdo's Avatar
Does anyone have 891s on the back of their 4runner? I do tow and haul a fair amount and am thinking of 891s over the 890s. But I dont want to go too stiff that it won't flex and or feel like a buck board on the road.
Old Feb 19, 2006 | 05:37 PM
slick858's Avatar
I would go with 891's! less chance of a major sag after towing
GO BIG OR GO HOME!
Old Feb 20, 2006 | 02:24 PM
Gerdo's Avatar
How rough do the 891s ride?
