tans stuck to block?
Old Feb 8, 2006 | 10:17 AM
kccorvette's Avatar
ok im trying to put in a new clutch and i have done everything that the book says about removing the trans. Im at the part where you should be able to pull the trans away from the block, but its not moving. I have removed all of the bolts and everything. Does it just require more force like when parting the drive shaft flanges? 95 4runner sr5
Old Feb 8, 2006 | 10:22 AM
snap-on's Avatar
nope should come right off. (perhaps a little gentle nudge with a pry bar but nothing hard for sure)
my guess is you missed a bolt somewere... how many do you have in your hand?
Old Feb 8, 2006 | 10:33 AM
kccorvette's Avatar
9 i got the 2 from the top and the rest where pretty easy
Old Feb 8, 2006 | 10:37 AM
Marc's Avatar
On another vehicle I once had the input shaft bearing seize on the shaft and in the crankshaft.
I had to use a hydraulic jack to seperate the trans. Very scary.
Old Feb 8, 2006 | 12:04 PM
Elvota's Avatar
Make sure the angle is right. I just did this job myself for the first time last week and had the same problem. Once I raised the tranny up a bit, they seperated fairly easily. Still had to pry gently to get things started though. My center bearing was in pieces once I got in there, so that may have been part of the problem.
Old Feb 8, 2006 | 01:58 PM
eric-the-red's Avatar
Did you get the bolt that attaches the starter, it goes into the bell housing from the front. That held me up for a while when I did my clutch.
Old Feb 8, 2006 | 03:50 PM
kccorvette's Avatar
i got it off and already have the clutch in, but now im having a hard time putting the tranny back up, but i guess you just have to keep trying till you get it right. anyway it got dark on me so i will finish tomarrow. thanks for everyones help
Old Feb 8, 2006 | 05:43 PM
89macrunner's Avatar
just a tip that ive learned while working on my yotas...if it doesnt fit perfectly..you're doing something wrong
Old Feb 8, 2006 | 06:39 PM
fierohink's Avatar
Something I've been using on the past couple clutch jobs I've done. Run a ratchet strap from frame rail to frame rail under the output of the trans and another looped under the bellhousing. Then you can raise and lower the front and back of the trans independantly. Plus you can slide the straps front and back on the frame rails. This has cut sooo much time off my jiggle-jiggle routine trying to trannies to line up.
Old Feb 8, 2006 | 07:00 PM
kccorvette's Avatar
thanks alot that sounds like its gonna work. its kinda hard to move the front, rear, and then push at the same time.
fountain
Dec 31, 2015 06:08 AM
JookUpVandetti
Sep 11, 2015 09:41 AM
Duppie007
Aug 20, 2015 04:39 AM
toofly1999
Jul 25, 2015 07:09 PM
lfcarrion3
Jul 18, 2015 04:05 PM
