Just finished Timing belt - coolant question
Old Feb 1, 2006 | 02:35 PM
ohio4runner4x4's Avatar
Question Just finished Timing belt - coolant question
Just finished up timing belt/water pump and spent some time searching on what coolant to use and I couldn't really find a consensous! The 4R now has 122K. I bought it with 101K back in July and got no service records.
So...I got a simple question......I drained the radiator and it appears that I got about 2 1/2 gallons out of it and the stuff that came out was yellowish/green. Does this constitute a good enough flush to change to long life coolant? Or should I stay with regular yellow bottle Prestone?
Thanks!
Old Feb 1, 2006 | 02:54 PM
vegaskurt's Avatar
I was always told to use the red dex-cool or the toyota red. But yes, do a flush. 2 gallons of distilled or so should do the trick.
Old Feb 1, 2006 | 03:11 PM
MTL_4runner's Avatar
Take out the thermostat just temporarily and flush the entire system with a garden hose until it come out clear. Then switch over to a long life coolant like Dexcool, Zerex (yellow) or Toyota red. Don't forget to flush the heater hoses too.
Old Feb 1, 2006 | 08:06 PM
Mr. Bob's Avatar
I would avoid Dexcool at all cost... that stuff is soo soo hard on cooling systems... Use the OE toyota long life red, if that is not a good option go with normal green antifreeze...
Old Feb 1, 2006 | 08:11 PM
Localmotion's Avatar
Im a huuge fan of the Red stuff myself. Thats all i use. I even keep it in a 1liter bottle already mixed incase i need it
Old Feb 2, 2006 | 12:43 AM
02SE's Avatar
So what is it about the Dexcool, that is supposedly so bad?.
I've used it for the last 80,000 miles. No problems at all.
If I take off the radiator cap, when the engine is cool, the radiator is spotless. Same with the overflow reservoir.
I've heard of problems in GM motors, but I believe that's just due to poor materials and seal designs on the GM motors.
Old Feb 2, 2006 | 08:40 AM
vegaskurt's Avatar
That is a ton of info.... I've only put a 1000 miles on my engine since I went to dex-cool. Guess I will look into toyota red for this summer.
Old Feb 2, 2006 | 10:49 AM
surf4runner's Avatar
long but
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
