The really small light bulb inside the hazard or rear window defroster switch
Does anyone have any idea where to get this one? I got my hands on a used OEM foglight switch from Japan for my 94 4runner, but when I was trying to figure out how to hook it up something was not right. Turns out there is a small lightbulb inside this switch (I assume it is the same setup for the Hazard and Rear heater switches since they have a constant backlight when your headlights are on), and this small lightbulb is not working. It' seated in a small white plastic socket, and it seems like it's stuck in there.
The bulbs in those switches and the sockets are all one piece. The socket has a phillips style head on the back of it and you rotate it a quarter turn to get it out of the switch itself. I went through this when I made all my backlighting blue. I broke a bulb off trying to get it out of the socket and then I realized it's all one piece. Toyota carries them. I went to a junkyard and swiped a couple. They are all the same for the AC, Hazard, Rear window, Rear defroster, ect.
I've been trying to track down the actual stock bulb that goes into those sockets. I called the dealer and the bulb with socket is $9.00, which is crazy. I need 3 right now and I'm not paying $30 for those teeny things.
After poking around and using a set of calipers, it looks like this might be an 8640 bulb. You can see one here -
http://bulbster.com/lightbulbs/8640-p-2475.html
The only thing is the wattage seems a tad low.
I'll post once I've ordered some.
Cheers,
DrA>
Cheers,
DrA>
voiddweller
19
May 2, 2016 09:10 PM
