Ok, how the heck am I gonna mount speakers here?
Originally Posted by DavidA
Cut a new hole through the factory location and mount them through it. Much better. I did that with 6x9's and it worked fine.
The factory grill is too restrictive acoustically.
vmax84
Here are the speakers I got for the rear for 39 bucks thru Crutchfield when they had them on clearance.
vmax84
http://www.blaupunktusa.com/NR/rdonl...0/tsc660_h.jpg
vmax84
You cut the hole using the template included with the speakers, then drop the speakers through the top. Since you already have the side panels off just run a bolt through the top to the back, then use a nylon locking nut to screw on the back of the panel. Will be very secure that way.
I would mount the tweeters higher up on the panel and use the angle mounts to point them to the front of the vehicle. Just drill two holes for it, one for the speaker wire and one for the mounting screw.
Hope that helps.
Hope that helps.
I don't know why, but knowing me, I'm gonna make a great big project out of this!!!
vmax84
The side panels are kinda flimsy. Seems mounting the speakers to the side panel will give too much flex. Will have to frog around with this.
vmax84
Make a bracket
You can make a bracket to fit pretty much any speakers you want - size permitting of course.
Here's what I did when I replaced my stock speakers.
My panels were very old and brittle, so cutting holes in them and hanging the speaker didn't look like it would last long, but with some reinforcement it could work too.
Erich
Erich
Erich
Erich
vmax84
I want to try and find a way of enclosing the speaker in its own little enclosure. Boxing them up would be easy, but the truck has limited stowage capacity to start with, so don't want speaker boxes in the truck. Need to figure out how I"m gonna box them in in the location behind the grill. Hmmmmmmmm......
vmax84
vmax84
Originally Posted by stoutshady
I would make an mdf baffle and mount it in that space with some wood screws. Then mount a nice 6.5" speaker on the baffle if the depth is big enough.
More beer and thought required!!
vmax84
Erich
Erich
vmax84
Originally Posted by vmax84
I like how this is mounted, but somehow mount it in some MDF.
vmax84
vmax84
Erich
It seems like that would work. I wouldn't go as thin at the ends as the one I made. You'd also have to attach the bracket on the back side of the tabs on your rig so you can put your back panels back on. Other than that though, it seems like MDF would work.
Erich
Erich
Erich
vmax84
vmax84
You could make it out of both MDF and some sheet metal. Cut a ring of MDF and then attach small pieces of sheet metal to the MDF at the top and bottom so you can bend them to fit to the tabs. That way you don't have to fuss with cutting a hole in sheet metal (Making mine was a pain in the butt because some idiot cut the cord on the plasma cutter right before I was going to use it
) Then you can use a couple bolts on the top and bottom to attach two sheet metal "ears". I wish I had thought of that when I did mine, would have saved me a lot of head scratching
Erich
FS[PacNorWest]: 1984 4Runner Asian carb original
user 82300
Sep 2, 2015 08:31 PM
Esibnitsud
Jul 30, 2015 08:19 PM
FS[PacNorWest]: Kick panel speaker pods
AkitaDog
Jul 27, 2015 02:38 PM
