98 4runner wont start, alarm/starter issue, need help ASAP!
edit: problem solved, removed pos alarm.
someone please contact me, whoever has recently installed an alarm/starter.
my pos prestige alarm/starter is really screwed up and this morning when i go to start it, all i heard was clicking from under the dash and the car would not start.
since its over 50 here in boston, i decided to just take the pos alarm apart. i just ordered a commando alarm which i will install in a few weeks. so now, after unhooking the brain from all the harnesses, its still not starting and i think some of the wires from the ignition harness is not hooked up correctly.
does anyone know what the green/black wire from the ignition harness is for? i think thats the culprit and its split up. someone please call and advise, thanks.
Originally Posted by Amir904
someone please call me. 518-265-9444, whoever has recently installed an alarm/starter.
Did you try jumping it and see if it starts (rule out a dying battery)?
like any alarm, there will be a bunch of wires from the alarm unit that will be attached/soldered to wires in the ignition bundle. what do you mean its "split up?" if you see wires soldered or tapped to the ignition harness AND you just want to remove the alarm, you can pull them all out and then the alarm will not recieve any power. or the easier and safer thing owuld be to pull every single fuse of the alarm system out. just follow the wires from the brain and you will find those inline fuses
bob
jamie, starter contacts were replaced a couple months ago, battery is an optima, 3 months old, i tested it with volt meter, over 12V.
its a funny situation, when i got in, the alarm went off, then after disarming, everything died. there was absolutely NO power what so ever. it was acting like there is no battery hooked up. then after every 5 min or so, the power would come back, as soon as i put the key in the hole, and turn, no power!
one other thing, when im sitting inside, as soon as i open the door, the dome light comes on for approx 1 sec and then, bam! no power!
there was crazy clicking sound coming from the brain, i think the alarm has had it. so i took apart all the harnesses and taps into the factory harnesses. but it is stilll acting the same. its funny but there was no in-line fuse. im gona go back to the installer and see why.
bob, what i mean by split is, that there is a green/black wire coming out of the ignition bundle and instead of going to the harness its cut in the middle and both ends go into the brain at different input channels. i did hook that back up, but still no go.
Sometimes if you take it apart and tap the relay it will work again (emphasize sometimes).
took the whole alarm off. its back to stock but will be installing a commando.
bob
voiddweller
19
May 2, 2016 09:10 PM
jmc88runner
Jun 18, 2015 03:39 PM
