Finally upgrade to XP and have a couple problems...please help
Ok I finally upgraded to Windows XP. My first problem is with McAfee. I was running it before and now it is listed in the add/remove programs list but isn't listed under my Start Menu and isn't running. How do I make it start working again? I noticed a change button under the add/remove programs list for it but I don't know what it does.
My second problem is with my printer. When I reinstall it, the computer does not see it when I plug the USB cable back in. I uninstalled it and reinstalled multiple times but always got stuck on the part where I plug the printer in because it isn't recognizing. I also tried unplugging the printer from the wall but that didn't do anything either. Any ideas?
Thanks for any help. I greatly appreciate. Hopefully now I can spend a little more time on YT because my internet is back up.
McAfee - reinstall it. That's probably the easiest way to handle that problem and prevent future problems.
Printer - sometimes "uninstalling" a printer doesn't completely remove old settings. If you go to your printers website, a few of them have tools that really completely removes all settings left by that printer. Also, make sure you're using the right printer driver. I've had instances where the one shipped with the CD wasn't the right one. Try the one downloadable from the printer's website.
I'd be surprised if these were all of the problems you're going to experience. Upgrading to Windows XP is never a good idea. The only time I would ever do it is over a clean install of Windows 2000. But I hope your luck is better than mine.
Problem ONE Youre running McAfee, GET RID OF IT. the Free Version of AVG is better than McAfee. You have no idea how many computers I've had to fix and remove virus's on and the users were running McAfee.
As for your printer problem. Did you download the latest drivers from there website ? check as mentioned above for a uninstall program.
Also check your device manager make sure all the motherboard USB Device drivers are loaded properly (No yellow ! beside them) and that there are not any other UNKNOWEN DEVICES listed.
Well McAfee was free through the school and that's why I run it. But I'll consider dumping it like you guys said. I fixed that problem by reinstalling it.
After looking in my Device Manager, I found I was having USB problems with my printer. Windows found a new USB driver and then I was able to successfully reinstall my printer.
Thanks for the help. So far XP is ten times better than ME was.
Originally Posted by Localmotion
I just got a copy of XP64.....ive heard great things about it, and only one bad thing..that there arent any drivers out there.
Ed
Originally Posted by 4Hummer
...the Free Version of AVG...
It's not terribly clear when you come blowing into the site that there's a separate server for the free stuff.
Jun 1, 2021 01:51 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
