what is the ultimate backspacing for R15 with a 32" AT tire
what would the best backspacing be for my 32" R15 x 11.5 yoko tires?
3.5? 3.75? 4? and why is it better then stock bs?
there is a guy selling some 15 x 8 with a 3.5" bs procomp rock crawlers around town for $50 a wheel.
Is this a good deal? will 3.5"bs work? i dont even know what the stock backspacing is on my toyota rims...any help????
Your stock BS is either 4.75" or 4.5"
Less backspacing will give you a wider stance, can reduce or eliminate rubbing bigger tires, makes for less chance of a roll over, and looks better/more agressive.
3.75" BS is very common. 3.5" will just stick out a tiny bit more. If your after a wider look, you'll definitely notice it. Will it work? Yes.
Really, theres no such thing as "ultimate backspacing" but 3.75 BS seems to be the most favored, plus they're easy to find or replace.
I'm not aware of any drawbacks other than you *might* have a chance of rubbing your tires on the outter fender seem when flexed/stuffed. I don't think you'd have to worry about that with 3.5" BS though.
Originally Posted by hill
what are the drawbacks of a slightly wider stance...lets say with a 3.5 BS rim?
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
