Parts from a Toyota 3.0 for sale
These are parts off of black beauty and some other misc sources they are for the most in great shape. All prices are negotiable and are plus shipping.
1. Wheel well trim pieces. Very good condition I think the front ones are new as of a year ago. $30.00 OBO
2. Front vailence off of the bumper in decient condition I straitened any dents out so its pretty much good to go with a bit of paint. Currently black. $20.00
3. A/C compressor from 3.0 V6. This was on one of our cores and we have no use for it. Never seen it run so who knows I'm assuming its good. $10.00
4. TPS from one of the cores as well. It tested good and it in overall clean condition. There are two types for the 3.0 so send me the part number off of yours And I'll see if it will work for you. $40.00
5. Cold Start injector tested good. $20
6. Cold start injector swich also tested good. $40
**EDIT**
I also have:
-a fan clutch seems good $15
-Power steering pump from the 3.0 with no signs of leakage $20
-Temp gauge sensor $20
-EFI water temp sensor $20
-COmplete EGR system throwing no codes so seems fine as well as some parts of another EGR system all from a 3.0. Make me an offer on this stuff.
-and 6 injectors for the 3.0, 4 look good and 2 look like they need a rebuild. $100 for all 6 or make me an offer.
**EDIT**
I also have:
I might be interested in the TPS. I'll get the number off mine tonight & get it to you tomorrow. Should I e-mail it to you?
There are two sets of numbers on my TPS
The top Number
89452-12040
The bottom Number
198500-0330
I'm definitely interested in the TPS if it will work on my truck. Thanks!
The top Number
89452-12040
The bottom Number
198500-0330
I'd be interested in the a/c compressor. Clutch intact?
EGR system is from my 89 truck and is actually still on the engine. I also have some misc componenents from a core however the core egr itself is toast. I'll pull the one off of my engine if you really want it, I'll be doing that eventually anyways.
Originally Posted by suprathepeg
I'll have to make sure the bearings are good tommorrow just to make sure you get a good one.
How's it look?
Is that $45 with or without shipping?
Didn't get a chance to look at the fan bracket I'll let you know tommorrow, IIRC it was fine but I just wanna double check.
PS pump is still here.
