Performance Enhancements Enhancements to improve your performance
Old Apr 19, 2016, 11:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Air Intake and Exhaust Guides
Print Wikipost
Intake Silencer Removal Mod - 3rd Gen 4Runner (2000)
Old Dec 31, 2005 | 03:32 PM
Bob_98SR5's Avatar
Installed on a 3rd gen 2000 4Runner with a 3.4 V6
There is a difference in the methodology on how to do this mod between the years. Posts 1 and 2 will deal with 99 to 02 4Runners while post 4 will deal with 96 to 98 4Runners.
Dr. Zhivago shows you how he did a mod to his air box here to improve the torque and HP on his 4Runner. This article details an inexpensive way to get some more Horsepower and Torque out of a 99-02 4Runner with the 5VZ-FE engine by making a modification to the intake system.
Take a look at your intake tubing between the Airbox and the Throttle Body. You'll see a wide, rectangular box with a hose coming out of it. That box is a "Resonator" or "Intake Silencer". They really should call it a "De-Resonator" or "Torque Destroyer". It is a series of catacombs inside that break up the Intake Pulses to quiet down the intake noise on the engine. It also robs the engine of some much needed torque. I'm going to replace that box with a piece of tubing of the appropriate diameter and length. That should net me around 10-15ft/lbs of Torque and about 5-7 RWHP. By the way, the hose coming out of the Intake Silencer goes to the Fuel Pressure Regulator (FPR).
Here's what we're removing:
Here's a picture of the intake system taken apart: (Thanks goes to JA for this pic.)
Every vehicle I've owned has had its stock intake system replaced or modified by me for better performance. In every instance, I've been successful. My reasoning for believing that removing this component will help is this: It takes time to fill that chamber with air. The air coming into the engine is not a constant stream. It is pulsing with engine RPM’s and the load placed on the engine. Inside the Silencer is a “slot” which traps the intake pulses acoustically and filters out the low frequency, large amplitude pulses. I believe the silencer reduces the maximum velocity that the air can achieve entering the intake polonium.
Here's a pic of the Slot inside that tunes out the pulses:
Air in motion is cooler in temperature than still air. Air of a higher velocity has even more of a cooling effect. I think everyone reading this knows about “Wind Chill Factor” and the effect of a cooling breeze on a warm day. Cooler air is also denser and it contains more oxygen. By increasing the velocity of air entering the engine, the air is cooler and more oxygen rich. The intake system contains an IAT (Intake Air Temperature) Sensor which tells the engines ECU what the temperature is of the air entering the engine. When the air is cooler, the ECU can run more aggressive timing curves which result in better performance. You ever notice how “peppy” your engine is in the morning when you first fire it up? This same cooling effect is the reason behind why the DeckPlate mod works. A larger amount of air, moving at a higher velocity, and therefore cooler air, is entering the engine with the DeckPlate off versus a stock airbox.
There have been some counter-points to this line of reasoning brought to my attention. Here is a link to some excellent articles on the subject. You can draw your own conclusions. I just wanted to make sure you had both sides of thought about this. I will say this about those articles; every engine is different, so not all of that information and testing in those articles applies to every engine. They're still worth reading all the same. Part of this counter-point is that if anything, removing the Silencer will change the torque curve and cause a loss of low-end torque. That has not been my experience. Read on.
I was speaking with Loosehead, another forum member about this mod before doing it. He has a 1998 4Runner with the 5VZ-FE in it. The intake plumbing is a bit different on the 96-98. He's the guinea pig for the 96-98 models. Anyway, I had taken measurements and knew the size of pipe needed, but I was having trouble tracking down the appropriate size. I wanted to use ABS or PVC, but no one had any that was the right size. Loosehead suggested I talk to a muffler shop. Great idea! I called a local shop, Master Muffler. They have several locations in the Portland, OR area. I told George on the phone what I was trying to accomplish. He was very helpful and even gave me ID and OD diameters for the various pipes he had in stock. None of what he carried was the correct size, either. However, he said we could expand the pipe to the right size. He told me to come on down and see what we could do. (I knew I had talked to the right shop.)
When I got there, we removed the Silencer to take some final measurements. We used 2.5" OD 14G pipe and expanded it on the pipe bending machine to the correct diameter and cut it to length. Then we cleaned up the burrs and brushed out all the stray pieces of metal.
Here are the dimensions needed for the piece of piping to replace the Silencer box:
Length - 5.625"
Diameter - ID - 2.5"
Diameter - OD - 2.625" ~ 2.75” (Larger than 2.75” OD will be a tight squeeze.)
Pipe is 14G Mild Steel.
George was awesome. He spent about 30 minutes with me working on this. I asked him how much for the pipe. "5 dollars." was his answer... I couldn't believe it either. Like I said, I knew I went to the right place. I gave him $6 because that's how many "ones" were in my pocket. I'm a big spender.
Here's what it looks like installed:
A close-up: (You can see my Magnacor wires in this one.)
After talking about this with some folks on the forum, I decided to get the pipe powder-coated so that it wouldn't rust. I think it gives the install an OEM appearance.
continued...
Bob_98SR5's Avatar
Okay, now that the pipe was installed, I needed to put the FPR hose somewhere since I lost the nipple on the Silencer. On the front of the intake plenum is a nipple with a small hose coming off of it. I purchased a ¼” Plastic Tee and about a foot of 7/32” hose. I cut a short piece about 2” long to attach the Tee to the nipple on the plenum. I attached the hose that was formerly on the plenum to the right side of the Tee and attached a 6” piece of 7/32” hose to the left side of the Tee and the other end of it to the FPR Tubing that runs under the plenum to the FPR.
Here's a pic:
I also purchased a new hose for the EVAP system. It's the hose that runs across the engine bay and attaches to the Airbox just Upstream of the MAF. It's stiffer than the stock hose and it doesn't “droop” onto the engine. The stock hose drooped when I removed the Silencer. I think this looks much better.
Here's a pic:
Total cost for Tee & Hose: $5.78
Total Cost of Pipe: $6.00
Total Cost for Powder Coating: $20.00
Total cost of Mod: $31.78
Okay, so now that this is all done, what did I notice?
Off the line and all the way through redline there is a noticeable difference in the engine's performance. It's more than I expected it to be. I think my estimate of 5-7 RWHP was a bit low. Acceleration at all speeds is improved. Throttle response is punchier and more immediate. Not only that, but the Intake Growl sounds awesome. It even beefed up the exhaust note. It's pretty Hot-Rod sounding. Of course, this could all be in my head, but I'm intimately familiar with the way my truck runs and sounds. Also, I was running a tank of Mid-Grade Octane to see if I noticed a difference and with the stock intake, I couldn't tell. With this new intake setup, I could induce pinging, which to me is a good thing because it means that the Ignition Timing is more aggressive and more air is entering the engine. It was back to Premium gas for me. This might have been caused by winter blend gas, but there was a difference. A tank full of premium gas ceased all pinging, by the way.
One other thing I noticed as I got to drive it a bit more and with more time on the freeway: The exhaust note at cruise is even quieter now. It's as if the engine had to "labor" more before to sustain the same speed than it does now. It's almost silent. When you get on it however, it has more of a growl than before, which to me is the best of both worlds. Quiet at cruise, but wakes up and announces it's presence with authority when you want it to.
After driving it around for about a week, I decided to install the DeckPlate mod to see if there would be a difference. Oh. My. God. I hate to sound like I'm making things up or exaggerating, but you gotta do this mod with the DeckPlate. I previously had been running with the Elbow removed because I didn't want to punch any holes in my shiny new truck. But now that I've got a few "unexpected modifications" from playing and other stupid stuff, I thought, "What the hell?" Again, I was not prepared for the amount of power gain from these two simple mods.
There is so much more power (at all RPMs) "On Tap", than before. It's amazing. The midrange especially is a godsend. Also, the engine "spools" much more quickly. So quickly in fact, that it makes me wish there was a bit more headroom before Redline. Another 500-800 RPMs up top would be really nice. Larger Cams will probably help with that. EL Prototypes is milling cams for these engines now, in case you weren't aware.
A caveat: If you do this mod in combination with the DeckPlate mod, the intake noise at large or wide open throttle settings is much, much louder than with the Silencer in place. It's similar to a large 4-Barrel Carbureted V8 with an Open-Element filter on top. It's very deep and throaty. I personally love that sound, but some may not. At lower throttle settings and at cruise, you can't tell a difference. If you do the Elbow mod in concert with this mod, it's not too bad.
Speaking of the Elbow mod in combination with this mod… It is my experience that the combination of the Elbow Removal mod with the Silencer Removal mod yields more power than the DeckPlate mod alone. This is just an FYI.
Another counter-point some people have made about all of this is that I'm “Fooled” into believing the engine has more power simply because it is louder. That would be true were I a fool. However, I am not. All my other senses do not stop working because my ears hear a loud noise coming from my engine. My eyes still notice how much more quickly my engine revs by looking at the Tachometer. My body still notices how much more quickly my truck accelerates and how much harder it pushes me back into the seat with the mod than without it.
Please take this article for what it's worth: My opinion and experience. I would never do something that I thought was going to harm my engine or give it worse performance. I certainly wouldn't recommend that other people to do the same. I am confident that this mod is worthwhile and that it adds a measurable amount of HP and Torque. People have requested that I Dyno test this mod. That will happen in the near future. Please check back for the results.
I am going to make some videos that will show how my truck performs in some “rolling acceleration” tests with and without the mod in place. I am confident that the videos will speak for themselves. Please check back for those really soon.
So, there you have it. If you own a 96-98 V6 4Runner, please wait for the companion article. I Hope this is helpful. If anyone tries this, please post back with your results. Also, if you have any questions, well, I'm sure you guys will ask.
Peace!
Dr. Z
Old Dec 31, 2005 | 03:46 PM
Bob_98SR5's Avatar
96 - 98 INTAKE SILENCER MOD WRITEUP IS BELOW
Old Dec 31, 2005 | 03:49 PM
Bob_98SR5's Avatar
Intake Silencer Removal Mod - '96 to '98 4Runners
Here we take a look at what's involved for this mod on the 96-98 models. It is recommended that you read the writeup above before reading this, you cheaters! I assume you know certain things for the sake of simplicity and so that I don't have to repeat myself.
The 96-98 models’ intake plumbing is different than the 99-02. Take a look at the pic below:
As you can see, compared to the 99-02 intake, there are a few boxes branching off of the main intake hose that runs from the output of the MAF to the Throttle Body. We will be eliminating Part #’s 9, 10 & 11 from the intake path. The mod isn’t accomplished quite as simply as it is on the newer trucks because of this fact. However, this can be a good thing. You have several options with this truck. I will detail them in order of the most expensive to the most frugal. At the end of the three options I will detail the items of the mod that are common to each option to avoid repeating myself several times.
Option #1 – 99-02 Intake Hose Replacement
The intake system hoses between the MAF and Throttle Body on the 99-02 4Runners will fit on the 96-98 models.
This is a pic of the 99-02 models. Parts 10 & 11 along with Clamps part # 13 will retrofit onto the intake system of the older trucks. Then you can make a pipe similar to the pipe made for the 99-02 trucks. I met up with YotaTech forum member Micker, who owns a 96 Limited. We test fit my intake on his truck and it was an exact fit. I would make the Silencer Replacement Pipe a tad longer than the pipe made for the 99-02 trucks. The reason for this is to give the intake a little “play” for engine movement.
Here are my recommended dimensions:
Length – 6.00"
The advantages to doing the mod this way:
1. Cleaner engine bay. No more black boxes hanging everywhere.
2. Smoother, straighter airflow path with the newer intake hoses.
3. It's a plug and play install.
The disadvantages are:
1. Cost is considerably higher than the following two methods.
2. I can't think of any other bad points… If it were my truck, I would choose this option.
The prices at the dealer for part #’s 10 & 11 for the 99-02 hoses are as follows:
Part #10 ~ $36.19 with a 15% discount.
Part #11 ~ $27.09 with a 15% discount.
I did a little searching a found the same parts at a wrecking yard for $45 plus shipping. This price also included the Clamps, part #13.
Option #2 – Plumbing End Caps
With this option, you lose the big black boxes, but keep the stock intake hose. You will need to purchase 3 plumbing end caps to plug the holes left by the removal of the intake resonator and the two silencer boxes. Below are the OD dimensions of the INLETS on the three boxes.
J Shaped Resonator – 1 11/16” OD
Front Silencer (Big Box) – 2 5/16” OD
Rear Silencer (Small Box) – 15/16” OD
There might be as much as 1/8” of room to go larger than these dimensions. Simply find some plumbing end caps of the appropriate diameter and clamp them in place of the boxes. Face the “Cap” towards the inside of the intake hose to minimize the size of the pocket it will create inside the hose. This will help minimize turbulence. You can use ABS, PVC, and Copper, Aluminum or Stainless Steel end caps. Whatever are the handiest and your own personal choice.
Advantages:
1. It's less money than Option #1.
2. It helps clean up the engine bay. No more black boxes.
Disadvantages:
1. The benefit of an “OEM” appearance is lost.
2. Not as smooth of an intake path as Option #1.
3. Might be difficult to find the appropriate diameter end caps.
Option #3 – The Quick and Dirty Method
Okay, you penny-pinchers, this one's for you. Grab that roll of Duct Tape you used to fix your leaking muffler and the same one you used to fix that crack in the block. Just kidding, but you gotta love Duct Tape. We are gonna use it for Option #3.
Remove the three boxes from your intake hose. Clean the inlets really well, then cover them with Duct Tape and reinstall them. Voila!!! You're done. I don't recommend this as a permanent fix, but at least you can check it out this way.
Advantages:
1. It's damn cheap! Who doesn't have Duct Tape?
2. Did I mention how cheap this is?
3. It's quick. (And cheap.)
4. You can “Try before you buy.”
Disadvantages:
1. Not a permanent fix.
2. It shows everybody what a skinflint you are.
3. It leaves those nasty big boxes hanging everywhere.
The Common Stuff - Stuff you just gotta do.
Okay, now that we've looked at 3 ways to make this mod happen, let's take a look at some stuff you're going to have to do no matter which option you choose. (This is Loosehead’s truck, 1998.)
See the hose attached to the top right corner of the Silencer? That goes to your Fuel Pressure Regulator (FPR). No matter which Option you've chosen, you've basically cut off air from reaching that hose. We will need to make a Tee fitting to attach that hose. This part of the mod will be just like the 99-02 setup. We can use the same parts for the Tee.
Here's the Pic:
I know what you're saying, “But there's TWO Hoses attached to the Silencer on MY truck.” Take a look at this pic: (This is Micker’s truck, 1996.)
Here's the Pic:
See the hose on the front of the Silencer that heads downward? It goes to your Power Steering Pump (PSP). You will need to use 2 Tee fittings. Connect the first Tee to the intake plenum as it is on the single hose systems, then add another Tee on the hose going towards the FPR Fitting, send one side of the Tee to the FPR and the remaining side goes to the PSP.
Okay. Well that's it for now! Thanks for stopping by. Good luck on this. If you have any ideas for more ways to do this mod for the 96-98 owners, shoot me a line and I will update this article, giving credit where credit is due.
Thanks goes to Loosehead and Micker for the willingness to be guinea pigs with their trucks and for providing me with great information.
- Dr. Zhivago
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
