Taco CV's - Where to get for the best price?
Old Dec 2, 2005 | 05:58 AM
MudMonkey's Avatar
During my last trip through a mud hole I discovered that I have torn boots on both cv's on my taco. Needless to say they filled up with mud and pretty much got destroyed.
Where is the cheapest place to get them? Does anybody make a stronger version of them?
Thanks in advance for your help.
Old Dec 2, 2005 | 06:29 AM
ZUK's Avatar
ZUK
about 30% savings here... http://1sttoyotaparts.com
Old Dec 2, 2005 | 06:37 AM
tc's Avatar
tc
autozone had ones for my 4Runner for about $70 with a lifetime guarantee
Old Dec 2, 2005 | 06:53 AM
MudMonkey's Avatar
OUTER CV JOINT, Tacoma, w/Auto Disc-Diff - 4WD TWO PIECE HOUSING 95-04 $343.50
INNER CV JOINT, Tacoma - 4WD TWO PIECE HOUSING 95-04 $226.84
Holy Crap! Maybe I should've kept my Acura!
Old Dec 2, 2005 | 10:03 AM
Those are absurd prices. I'd stay away from the autozoo ones. Parts chain stores take the shafts and grind them down then use oversized bearings and such. If you want stronger call George Stuckey at CV unlimited
Old Dec 2, 2005 | 10:06 AM
Localmotion's Avatar
the ones from Autozone are fine imo. They arent built beefier, but have a life time warranty! They are really cheap too!
Old Dec 2, 2005 | 11:04 AM
Nitro Hotpants's Avatar
I suggest you look at junkyards for some used ones. The manual hub axles are actually hardened from the factory, thus stronger. (I am assuming you have manual hubs?)
When I broke mine in Colorado, it was not just a clean break, you can see how the metal twisted and even bent the splines. On an ADD axle or an aftermarket axle, they are not hardened and will break easier.
Don't skimp on axles, get used ones and rebuild them.
Old Dec 2, 2005 | 01:30 PM
MudMonkey's Avatar
No, unfortunetly I have ADD.
Old Dec 2, 2005 | 04:46 PM
rocket's Avatar
Try this guy... https://www.yotatech.com/forums/showthread.php?t=72371
Old Dec 2, 2005 | 06:54 PM
My understanding is that the aftermarket axles they sell you at Auto Zone or whatever are about equivalent in strength.
You can take your stock axles in as a core and spend a lot less.
Old Dec 3, 2005 | 03:19 PM
There is no comparisson on the stregnth of AZ vs stock axles. Spend a day somewhere that makes CV shafts like CV unlimited and you'll learn alot about CV's. Go the the junkyard and get a set or go somewhere like CVU. CVU had a setup at one point using tundra outers
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Nov 9, 2015 11:53 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
