What locking differential would you suggest
Old Nov 30, 2005 | 08:47 PM
SWOULTER's Avatar
Well id search but it is pretty late. Well I do some recreation offroad and Im just looking for a solid differential that can lock and unlock pretty easily. Drive mainly to school and stuff. Any opinions for something
I know from other sites ill probobly get tolded to search but i will after this one.
Old Nov 30, 2005 | 08:50 PM
garrett1478's Avatar
yeah the search function shuts down around 11...
looking to go cheap? selectable? automatic? read all about them right here:
https://www.yotatech.com/forums/f31/locker-faq-43572/
and here
https://www.yotatech.com/forums/f31/calling-all-people-lockers-65334/
Old Nov 30, 2005 | 09:42 PM
Adam F's Avatar
Theres only 2 selectable lockers out there for the Toyota REAR axle (only one for the front, ARB) Toyota elocker or ARB air locker.
I choose the elocker, and explained it on my site, along with how to retrofit it into your axle
http://www.toyotaoffroad.net/afertig/88/elocker.htm
Old Nov 30, 2005 | 09:47 PM
marko3xl3's Avatar
Unless you want to change out your whole front 3rd, then you could have an e-locker in front as well.
Old Nov 30, 2005 | 09:48 PM
Localmotion's Avatar
do you already have the toy?
If so, go with an ARB
if not go with an e-locker.
Do a search...the great thing about YT is that its 24/7!
WELCOME!
Old Nov 30, 2005 | 09:49 PM
CoedNaked's Avatar
What about an "Eaton" locker?
Old Nov 30, 2005 | 10:30 PM
deathrunner's Avatar
As far as auto lockers go, I love my aussie locker.
I hear great things about the detroit softlocker, woudl be a bit stronger, but install would cost more.
Old Nov 30, 2005 | 11:21 PM
rockota's Avatar
Doesn't exist for the Toy. Adam is 100% correct. And no, a person cannot swap out a later model IFS front diff to get the ARB - the diff is on the wrong side of the truck.
Old Dec 1, 2005 | 03:30 AM
Ltl_Red1's Avatar
I love my lockrights in the front or rear if you can handle the wheels being fully locked all the time. Since it seems you're using it mostly for a DD, I'd recommend going with the ARB. That way, you'll also have on-board air. It's a good chunck of money up front but I believe it's well worth it.
Old Dec 1, 2005 | 03:36 AM
bamachem's Avatar
ummm, the only 4runners that have a front thirdmember is a 84 or an 85.
everything else is IFS and has a front differential...
no front differentials can be retrofitted to have an e-locker.
Old Dec 1, 2005 | 03:56 AM
JuttyShabango's Avatar
X2 on the Aussie, we put one in Vince's front end and it was a very straight foward install and works awesome. Shipped to the door for 260.00 Now that's a damn good price for the quality of it. Top notch.
Search more like the others have mentioned and one more suggestion. If people give you a suggestion on a locker...make sure they have ran one before and not just regurgitating what they've read on the net or hearsay.
There are finite differences between all of the different brands and methods of locking a diff and lots to do with driving style and terrain.
HTH
Old Dec 1, 2005 | 04:16 AM
99_Runner's Avatar
If it's just your DD and you don't wheel every weekend, but want the security of a locker when you need it then go selectable. Get an ARB or an E-locker.
Old Dec 1, 2005 | 09:54 AM
Cargun's Avatar
It would help if we knew what kind of truck you have. That can make a difference in what lockers are an option.
bamachem, "differential" doesn't refer to the IFS differential anymore than it refers to the differential located in a solid axles 3rd member. But yeah, no E-locker for the front of an IFS rig.. which we don't know if he has an IFS or solid axle since he hasn't posted details of his rig yet.
Old Dec 1, 2005 | 01:48 PM
AxleIke's Avatar
yeah, differential is just the gears inside that differentiate power between wheels.
Eaton only makes junk for dana, gm and ford axles for now
elockers only fit the rear
Old Dec 1, 2005 | 01:53 PM
Cargun's Avatar
Please tell this to all the people that I've met running e-lockers in the front of their rig so they can immediately pull the e-locker out and give it to me for free
Old Dec 1, 2005 | 03:04 PM
AxleIke's Avatar
How did they get it to fit, the front IFS is set up so that you'd have to cut the housing comepletly, and even then it would be hard. Perhaps you are refering to the SA, in which case i would say you are right. But i was talking about IFS which i should have clarified. Sorry
Old Dec 1, 2005 | 03:40 PM
Randomness's Avatar
Are there any reasons NOT to use the Aussie?
Old Dec 1, 2005 | 04:12 PM
SWOULTER's Avatar
Ya, that probobly would help. I have a 91 22 re pickup with some 31 inch tires.Thanks for youguys help. Im new to this site but i liek it so far. Late
Old Dec 1, 2005 | 04:24 PM
rngrchad's Avatar
Lockright.Cheap/Easy/Functional.
Or what Radomness said: Go Aussie of you can find'm.
Old Dec 1, 2005 | 04:50 PM
hayduke's Avatar
would a lockrite or aussie be good for a daily driver?
