Help me check my tranny fluid!
Old Oct 22, 2005 | 03:10 PM
rdlsz24's Avatar
OK I have both Haynes and Chiltons manuals for my truck ('88 22R 4WD 5-spd), but neither of them are helping me check (and most likely fill up) the tranny fluid. They each say there should be a 17mm bolt on the side of my tranny that I take out and then can check the level. Well I don't see a bolt matching that description on either side of my tranny. So I took pictures of each side of my tranny hoping you guys could tell me which bolt I need to take out.
Here is the driver side:
Here is the passenger side:
I thought it was the right bolt in the picture of the driver's side, but that is a around a 15/16 bolt. Also, the left-upper most bolt in the passenger side picture looks promising, but it takes a torx to unscrew it, not a 17mm.
Rob
Old Oct 22, 2005 | 03:25 PM
Nic's Avatar
Nic
I do believe it is the bolt on the right on the driver's side picture (top picture).
The bolt head is bigger than 17mm if it is the same as mine. If it is, it is a 24mm
Old Oct 22, 2005 | 03:52 PM
bob200587's Avatar
its the one on the right up there, I forget the size, might as well change it if you haven't in a while.
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
