Can you buy just uniballs to replace balljoints?
I need to replace my balljoints but wuld like to get some a little better then balljoints if I can. I've looked a bit into uniballs but can only find them in long travel kits. Is there someplace where I can buy uniballs to replace my balljoints without buying a big kit> what else would I need to make them work in my '90 4runner?
Dennis
Dennis
you cant jsut buy a uniball..... they pass through a specially designed control arm meant to handle it..... if htat makes sense... also a uniball up top, without the long travel would be pointless as the bottom could exploit any of the extra travel
86-95 4WD Toyota Lower Uniball Conversion
TOTAL CHAOS offers the first and only balljoint adapter that converts any 86-95 lower control arm using the factory ball joint and spindle to a 1" Teflon lined Uniball. Revolutionary in design, this billet machined Uniball cup simply bolts to the stock spindle. The conversion kit upgrades the lower balljoint that frequently becomes worn and damaged under extreme off road use. Drilling the lower control arm tapered hole to a 3/4" hole is the only modification needed to perform the installation. The 1 piece billet Uniball cup registers into the spindle just like the factory balljoint. Hardened stainless steel hi-misalignments and custom machined hardened bolts are included in the package and ensure maximum travel. This complete kit will fit any aftermarket or stock suspension that retains the factory balljoint and spindle.
As for the upper ball joint, currently there's nothing avaliable for stock width rigs.
It is the A-arm as well.I just looked at Camburg and they have more or less the same thing with the uniball A-arm replacement. Would this mean that I could go this route and not have to deal with the lower A-arms or a long travel kit. I need to replace my balljoints I just want to up grade what I need to and I think going with a full long traverl kit is too much money and more then I need...besides that my wife wants to go to Vegas and is having a hard time with me spending "more" money one my truck lol.
Dennis
Dennis
MMA_Alex
25
Apr 18, 2017 05:07 AM
skoti89
Jul 8, 2015 12:05 AM
