burning oil
Old Oct 10, 2005 | 04:26 PM
gilkey's Avatar
burning oil
on a 22re with 208,000 on it, is it normal to be burning 1/2 quart of oil every 3-4 tanks or so of fuel, if not what could this mean?
Old Oct 10, 2005 | 04:47 PM
Elton's Avatar
Did u do a Search
Old Oct 10, 2005 | 04:50 PM
waskillywabbit's Avatar
any number of things...most likely, engine top end rebuild time...w/ 208K on it, might be time to do the whole thing...just did mine 5K ago and it runs like a new truck...worth every penny
This thread should be in maintenance & repairs section.
Old Oct 10, 2005 | 05:20 PM
gilkey's Avatar
yes i did a search, the only problem is I can't afford an engine rebuilt or top end rebuilt. The cars in good condition i dindt know if this was just normal for a car this old and can be lived with, or if its a major problem. what you guys think?
Old Oct 10, 2005 | 06:15 PM
Nic's Avatar
Nic
What weight oil are you using?
Old Oct 10, 2005 | 06:32 PM
coryc85's Avatar
I get about 200 miles to a tank, so assuming you get similar mileage, you burn about a half quart in 800 miles. I've seen a lot worse than that, so if you don't want to invest any cash in it right now, drive it as is. Run straight 30W or heavier, keep it topped off and drive it til it starts spewing smoke.
Old Oct 10, 2005 | 07:54 PM
khaug's Avatar
To give you some perspective, the old Chevy I drove for 6 years through college burned one quart of oil every 200 miles, regular as clockwork. Don't worry about it. The worst that's likely to happen is that you'll eventually fail an emissions check. If this isn't an issue for you, just be sure to keep the oil filled.
Good luck.
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
calderp
Jul 27, 2015 09:58 AM
HookahRoo
Jul 20, 2015 07:06 PM
rushw
Jul 18, 2015 01:46 PM
