32X11.50R15 MTRs
would 32X11.50R15 Goodyear MTRs fit ok on a stock lift runner with 15x7 wheels? does anyone know if there will be alot of rubbing? should i go with the 31s instead?
i tried 32's stock and they rub in the rear of the wheelwell slightly. Do bj spacers and dlock or add a leaf for only a coupl ehundred bucks and you can fit 32's with ease. Oherwise just stick with 31's which are awsome...
Originally Posted by jimabena74
32x11.5s are probably going to rub on a stock vehicle
I've had 32X11.50 on my 92 at stock height with the factory 15X7 wheels and with 15X8 wheels and there was only slight rubbing while turning sharp and flexed. I would say go with the 32's, they look much better and if they do rub for some reason on your 4Runner it is just a reason to do a small lift.
Originally Posted by Randomness
They don't rub. They'll be fine. My only regret is that I didn't go with 33x10.5's. Those would fit fine, too.
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
