what happens when switching from 16" rim to a 15"?
It is about time for new tires. Truck is stock, 265 70 R16 tires on the TRD rims. But, you know, black steely rims look so cool.... i was price shopping and black rims in a 15" are on sale. tires are also a bit cheaper for that size (265 75 R15 to maintain 32"). my question is does doing this kind of swap do any harm/good? other than boosting my ego because my truck will look so cool in black. Or is there more to this than I'm realizing (brake interference or something)?
On the 4runner. I don't think there is that concern on the Tacomas. I tried test fitting steel 15s on mine and it seemed to fit just fine.
If your overall tire diameter remains unchanged I don't *think* you'd run into any problems. Though I have heard of problems balancing the black steels.
Originally Posted by bamachem
ahhhh, i thought the newer tacos that came w/ the 16" wheels also had the same brake system as the 4runners w/ the 16" wheels... i could be wrong, though.
Your best bet is to test fit the rims. That is the ONLY way you are going to be 100% certain they work for your set up.
Mine came with 16" rims and I am running 15" black steelies just fine. But, it depends upon the brand of the rims.
I had asked the same question but in reverse (moving from 15" to 16") and the few replies said it was not possible. I just put on 16" wheels but would not buy them unless the seller could put them on the truck. I checked to make sure the brake calipers and control arms didn't rub and it worked for me. Good luck to you.
BTW, I know a guy with a late model Taco (not the newest but the one prior) and he swapped 16" wheels for 15" w/o a problem. Went the same route as you b/c of tire costs...
Originally Posted by geneius
So, on a 98 4Runner w/ stock 16s...can I put my 15x8 Rock Crawlers on it?
I'm confused, some say yes, some no. Someone please clarify.
1uzRunner
63
Nov 10, 2018 03:58 PM
runnermedic
13
Sep 21, 2015 05:20 PM
