Redline D4 ATF (I searched)
Old Aug 31, 2005 | 10:09 AM
2000t4r's Avatar
I wanted to know if anyone is running this atf fluid in there 4runner. I contacted Redline and they informed me that that is the correct fluid for my truck. I'm unsure since I have not been able to confirm any of this information on the board.
Thanks
2000t4r
Old Aug 31, 2005 | 05:34 PM
KZN185W's Avatar
I use Red Line High Temp ATF (Dexron II/III) on my truck. Red Line D4 ATF meets Dexron II/III and the newer Dexron IV requirements. So, yes, it should be ok to use on your truck's tranny. I believe we have the same A340F tranny which requires Dexron II ATF as a minimum.
HTH.
Old Aug 31, 2005 | 06:47 PM
Ironmike4x4's Avatar
You should be fine as Roy said above. It's an upgraded version of Dex 3.
Ilovemountains
Jan 13, 2011 12:31 PM
Noel
Aug 3, 2005 09:53 PM
J95runner
7
Apr 6, 2005 07:13 AM
Duc Hunter
Mar 5, 2004 04:20 PM
