Switching to synthetic oil?
Old Aug 26, 2005 | 08:22 PM
2000t4r's Avatar
I have been searching for a few hours now about different fluids for my 2000 4runner. I have figured out that I will be running Mobil 1 products in my tranny,front and rear diff's and transfer case.
Can someone please confirm that these are all the correct products to use:
Tranny: Mobil 1 ATF 16+ qts (I will be flushing the entire system)
Front Diff/transfer case: Mobil 1 Synthetic Gear Lube LS 75W-90
Rear Diff: Mobilube HD Plus 80W-90 (If I can find it locally)
If I can't find the Mobilube locally can I use the 75w-90 even though the manual calls for 80w-90?
Thank you for your help.
2000t4r
Old Aug 26, 2005 | 08:55 PM
4Crawler's Avatar
75W90 is fine in the differentials. I think the 80W90 is specified by Toyota to match what many non-synthetic oil weights. Most synthetics have a wider range than conventional oil.
Old Aug 26, 2005 | 09:44 PM
humanoid's Avatar
Yeah, you should be good to go!
Old Aug 27, 2005 | 07:35 AM
2000t4r's Avatar
Thank you very much for your help
Old Aug 28, 2005 | 06:45 AM
kevin444's Avatar
Make sure not to use mobil 1 synthetics for ATF. My tranny didnt like it. and Mobil said it's not reccomended. Either stick with the toyota stuff or go amsoil syn atf.
Old Aug 28, 2005 | 07:50 PM
2000t4r's Avatar
Is anyone else having a problem with Mobil1 syn ATF? I did a search and it seemed that alot of people are using it due to the availability if it. Now I'm unsure of what to do, what about BG ATF syn fluid? I can get a good deal on it.
Old Aug 29, 2005 | 05:08 AM
KZN185W's Avatar
You might like to consider Red Line Lubricants.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
94yotaky
Jul 23, 2015 07:50 AM
HookahRoo
Jul 20, 2015 07:06 PM
Gamble_STi
Jul 7, 2015 07:54 PM
