how can i get the most out of my 2.7liter 3RZ?
hey i was wondering what kind of performance mods would be good and what brands for getting some more horses out my my truck. without a supercharger or turbo.
When it comes to all the mods and the so called "special" air filters and airbox deck plate mods it's up to you. If you change your air filter with every oil change the special filters are not needed. The deck plate mod will help a little with power if you think you need it.
I love my 2.7 and it has never let me down on or off road. Put it in 4 wheel low and low range and it will climb a wall! Have fun with, Mike
The deckplate mod and a K&N drop in filter will help, I did both and I have been very happy with it. Soon I will be replacing the tube that runs between the air box and the throttle body with something that allows it to flow a bit more smoothly. I figure once this is done I will be getting performance equal to an open air setup like AEM or K&N FIPK but I will have the ability to close it when I go offroad. I don't know what you are running for gears or tires but, while not adding horsepower, regearing to better match your tires will give you a bit better pick up and gas mileage. I know mine feels like crap on 3.58's with 31's...not for to much longer though... :cry:
I own a 3.4 and a 2.7..Compared to the 3.4 the 2.7 gets excellent mpg.Becareful when you mod it.You can wind up with worse mpg than you started with.Check you tire press and get rid of all the extra junk you dont need to haul around with you.then check your mpg and see the diff.Jack rabbit starts will eat gas quicker than anything else.Good luck.
junkyard turbo??
Just a thought. im not sure if it will work, but has anyone ever tried to rob a stock turbo off an old supra or celica? They have the same 2.7L motor just with a stock turbo and I know those cars will fly and get pretty decent mileage. Will this work for 4x4 taco? just wondering because it hase to be cheaper from a junkyard than a brand new turbo kit. Let me know.
2.7l Supra and Celica?
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
Uisge Beathe
13
Nov 16, 2009 10:11 PM
riverrat
Oct 2, 2008 07:29 PM
