How do I compress at full the rear suspension?
Hello,
I'm with a shock dilemma so I want to measure the compression and extension without shocks but I don't know how to compress enought the rear coils as to touch the bump stops...
I've never seen the axle touching the bumpstop but I suppose that in special situations like big dubbies it will touch...
Can I achieve the max compression by running up a ramp in reverse? I'm not sure if so I'll get the coil compressed at max...
David
David
This will usually do it for a stock or mildly built rig:
More info:
http://www.4crawler.com/4x4/CheapTricks/Ramp.shtml
More info:
Thanks Roger, those ramps seem low but your truck is a lot flexed... I suppose it's because you put them like dubbies, each one in each side...
I'll try to get something similar, but now I only have some wood planks and trunks that support quite well the truck weight.
David
David
If I place the jack in one side of the axle and jack it up I don't achieve to touch the bumpstop. There's a moment when the coil stops compressing and the front suspension begins to extend in that side and to compress in the other...
I think Roger's method will be the best.
David
David
Jun 1, 2021 01:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
Vargntucson
Jul 4, 2015 12:15 PM
1985, 4runner, automotive, coil, coils, compress, compressing, fullth, lift, ome, rear, shock, spring, suspension, truck
