2cnd gen V6 A/C condensor fan question
Old Jul 15, 2005 | 05:37 PM
Marc's Avatar
Hey there. To owners of 2cnd gen V6 4runners with air conditioning.
I installed aftermarket A/C on my 91 runner along with the Taurus fan.
I've set up the fan so it kicks in when the A/C compressor is on to draw air throught the condensor.
I'm thinking about going back to the stock engine mounted fan and was wondering if the stock A/C setup included a pusher fan for the condensor.
I guess I'm hoping my A/c will work fine without a pusher fan.
Thanks.
Old Jul 15, 2005 | 07:45 PM
93ToyKid's Avatar
Nope. No pusher. Should work fine.
Old Jul 15, 2005 | 07:51 PM
ChickenLover's Avatar
Yes. My 95 has a small pusher fan (stock) for the condensor.
Old Jul 15, 2005 | 09:21 PM
Marc P's Avatar
I have a pusher on the front of my 95, and the Taurus pulling.
Old Jul 16, 2005 | 07:11 AM
Marc's Avatar
Thanks for the help guys. It looks like the earlier 2cnd gens did not have the pusher.
I'll give mine a try without.
Old Jul 17, 2005 | 11:19 PM
jns's Avatar
jns
My 91 4R SR5 3.0 has a small pusher fan on the pass. side of the condensor. I also have a taurus fan and am installing a 140A alternator so I can run the fan on high since the stock alternator ain't cutting it. Why do you want to switch back to stock? My bearing plate went bad($950. for the part alone) so I had to go electric to keep the 4R on the road.
Old Jul 18, 2005 | 05:16 AM
Cebby's Avatar
My 93 has the AC pusher.
Old Jul 18, 2005 | 05:24 AM
bamachem's Avatar
don't get a new alternator, just get the proper controller for the fan and it will only run as fast as it needs to...
https://www.yotatech.com/forums/f2/electric-fan-variable-speed-controller-installed-61008/
Old Jul 18, 2005 | 07:34 AM
Marc's Avatar
jns, The Taurus fan has been working great for the last year and a half but, I've been towing various trailers ranging from 1000 to 3000 pounds this summer and find that I'm running a bit hot on the hiqhway, whether I'm using my A/C or not.
I never has this problem with the stock setup, so I'm hoping it stops the running hot.
Old Jul 18, 2005 | 08:23 AM
Flamedx4's Avatar
Mine doesn't have an electric fan. No problems with AC or engine heat. (Gave it a really good test this weekend, no worries.)
Looks like *maybe* the 5speeds didn't have an aux electric fan and the autos did, perhaps because the radiator, a/c condenser, and trans cooler needed the boost.
Old Jul 18, 2005 | 08:39 AM
94x4's Avatar
Guest
I'll have to chime in with bamachem's advice on the "proper controller" (check out his post for the link) as you'll be much happier with that setup.
Also, have you done the "Big 3/4" grounding wire upgrade to help the altenator with the battery's charge recovery ? These upgrades all kinda go hand in hand and/or compliment one another... if you're gonna go, you should go all the way !
Old Jul 18, 2005 | 10:36 AM
Chuki's Avatar
90' Runner, with 5 speed and I also have the small pusher fan in front for my A/C
kawazx636
Oct 6, 2021 03:03 PM
Badlander
Oct 10, 2015 08:05 PM
voiddweller
Oct 2, 2015 07:47 AM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 20, 2015 05:40 PM
